Whats the likelyhood of YT throwing a cage in one of the Mazda 6 and I jump in with you and we shame a few ppl?
Matt doesn't realy need a service crew and its been far too long since I sat next to you
Good luck to all the SAU peeps heading down and competing in WP.
Oh an Liam (bazil) can't believe what a small world it is....your old man drove me and the family around in NSW last weekend :) Got talking and he mentioned he was heading down for the event and drove a GTR with you.
I know! lol
But but, she won't be back, gorne too far now to turn back! lol
I'll just have to lease Savman's off him for an assault on team Newton/"FIGJAM" :P Although, reading through Sav's build thread, it does appear that car is trying just a little too hard, would rather turn up with a daily driver with a cage :)
:P
ye gods. focker friendships have been killing our rural cousins for decades now. I'm unlucky enough to have been in one before. never again. do they still make all the passengers launch the thing flinstone style down the runway for take off?
So looking at Rally Live ... http://www.sportcom.com.au/targanews/index.php?option=com_content&task=blogcategory&id=20&Itemid=69 seems Blaise is off to a screamer, but Snowcone not being listed...hopefully he is having a better run then he did last year....but doesnt look good :(
I am on the list mate - you just aren't looking far enough down it. :)
It seems the Blue car with a busted upper control arm was still faster than this new car is! LOL
I might have to follow Rickards path and get an EMO. Seems to have worked for him.
Kel has come home 4th again, a big step above strapped into an ambulance but still not the podium she was looking for. I imagine she is taking it out on the Targa Bar right about now. Wonder if she will lose her phone, or her shoes, or both this time?
seems emos were the thing to have in GTR class (EM) this time around. Good to see Ayres' rebuilt 400R come home 3rd though
Modern:
White Lambo alphabet
Glenney rx8 (must drop by mazda and buy an rx8 turbo, they must be special)
Quinn r35
EM:
Newton Emo
Paris Emo
Ayres 400r
Showroom
Reeves Mazda3
De Britt Astra Turbo
Dodd Mx5
Classic
Who cares since skylines were banned
Liam were you 847? If so well done on getting through in 1 piece :D
Well I made it - just! LOL
I have to say that event just isn't kind to me. If I ever think of doing it again someone remind me not too.
I *think* we are finally getting somewhere with the car but is hard to tell as with the extra speed we found after playing with the shocks we found an electrical gremilin that meant we kept blowing ignition fuses. They were going at really high G load situations. And it's fun at 160km/hr when you suddenly lose all power I can tell you right now. Finding the cause will probably be even more fun. So was having to drive with out all of my electronic talent as I stole fuses from places to put back into the ignition location.
Shows just how awesome that Wooster guy must be! :)
But the couple of clean runs we did have put us back in the top mix on those stages. So we have 8 weeks til the big one and I am feeling better about its chances now than I was Saturday lunch-time. And I was also really pleased to see Ayres get his mojo back on the Sunday too after a few tweaks. As I was beginning to think we all needed to get rid of the GT-R's and follows Rickards path down EMO land!
Thanks Jack.
Initially no - they made no difference at all. But that doesn't mean they aren't going to be better than what I had - infact I am sure they will be.
But it seems that the problem was in the bump setting on the shocks. They were both fully closed off which meant the car had no bump at all.
This meant the car had no lean in on turn in and kept the back sliding around the whole time.
We have only initially changed this setting from full hard to right in the middle but I reckon with some more tweaks we can get it bang on. The back I think needs to go further softer still. Unlike the old Teins we ran these MCA's make MASSIVE differences when you play with the clickers. I'm not sure who set them all to full hard but the guys who were helping me out with the advice on what to look for (Steve Glenney and Dean Herridge) both laughed when I told them where they were set too.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
