Ok, lets condense three years into one post...
I started with this and drove it twice
did this
this
and this
got some of these
did this
got some of these
these
these
and one of these
as well all new ones of those
and so far we've ended up with one of these
Given a few more weeks it should start looking more complete...
but truth be-known I should have just kept this because i'm pretty sure it could be faster and looked tougher than the rx-7 ever will ever be!
PS. R32 GT-R's are eligible for Classic Targa Adelaide (announced today to be run in September 2011)... have been over the course and a good 32 couldn't be a bad thing on the roads!
PPS. Yes Woo, on to it mate.
In case anyone is wondering about the best on-board camera to get, the RadCam HDPro has been selected as the official video camera for entrants in the 2011 ARC. We've put a special kit together to meet broadcasting and mounting requirements. This kit would also be ideal for Tarmac events.
Here's the link
Here's the link
Pretty good things, the only criticism is buyers need to be very careful of where the power button is. A friend borrowed it and I didnt give him the remote which meant he had to handle the unit to stop and start and becase the power button is on the side, every time he grabbed it, your fingers cant help but press the power button which if shutdown before stopping the recording you will lose the footage.
I had some strange problems when i first got it, which due to the average battery life I needed to be using power from the ciggy lighter. Problem was it was cutting out which means the file was not being properly closed and I was losing footage. I have since replaced the ciggy plug with a better one and the problem seems to have gone away. (Though it could of been the wiring in the hire car i was using) My mates problems with it had me thinking the problem had returned but realised what was going on when going through the operation of the thing with him and saw that he wasnt being careful enough when handling with relation to the power switch.
So use the remote to stop (ie save) the footage, be aware the battery life isn't great and make sure the ciggy lighter power supply to the thing is rock stable. The quality of the footage is good, sound is great once you have a play with it...
yeah I agree with troy. those little problems were small but were enough to make me stick with my POV. it's easy to use and never fks up and runs for bloody ages on 1 set of AA bateries. when the radcam would lose power half way through a day the pov was running for a couple of days straight on one set of batteries and even then I only changed them for a new set as a precaution against losing footage like what happened with the radcam. the footage was great but when you loose your best nurburgring sessions and the best half of a day a spa francorchamps because the thing kept switching off without us realising then it's a pretty joyless excercise. the real sad part is we used the pov as the incar looking back at the driver/nav point of view and the radcam in the usual over the shoulder view (which of course gives the best footage) so we had heaps of great facial expression footage from the reliable pov but bugger all great driving footage (not that I any of my footage would have been 'great' anyway... lol).
Some coments:
The unit has a key lock function which is very easy to use. It stops any button being accidentally pressed once recording is started.. You can still use the remote to start and stop recording though. See user manual for instructions on how to use this function.
Clips should never be lost if the power switch is turned off while recording. it will go through a proper closedown cycle before shutting off. In fact, that's how I use mine all the time. The only exception would be if you pulled the battery out while recording.
Battery Life: The RadCams now have upgraded batteries and we consistenly get a minimum 2 hours solid recording time per battery. We also supply 2, so just change when the battery indicator shows low charge. I just plug mine into the cigarette lighter in between runs. Black Magic Media use these in the ARC etc and have no problems with battery life.
While the POV's were good for their time, they are no longer considered broadcast quality. Top Gear Australia recently evaulated both the POV.HD and the RadCam and picked the RadCam due to its superior image quality and the ability to seamlessly run on external power. The POV.1.5 and the HD version will lose the clip every time the external power is disconnected as it has no batery backup. The POV.HD now only has short battery life and is still running on AA's instead of moving to Lithium.
How much for the upgraded batteries? Is the 2 hours at full HD quality?
Also, the file wasn't lost I have the files, they just dont play :) When the camera powers down due to low battery the file may be saved and exists...but its file format becomes corrupted. I really need 3 batteries to get me through an open pit track day. Sprints are ok as you only get 40 mins on the track. The 12V supply is great, you just need to be sure that the plug and your cars socket like each other as on the little Lotus you plug it in, light came on....but a bit of vibration and it lost contact and in turn charge (even though it was still plugged in)...hence low then dead battery :(
But the quality is well above the POV....maybe mine and its owner have been dropped on their heads too often....and dont get me wrong Mark. I am not intending to be negative or knock the product....I am not posting here anything I have not shared with you via email....just sharing the quirks of my experiences with the product in case others are considering it...think of it as a product review :)(I should add wasnt mine one of the very early ones sold and you did a great job to get it shipped off to the UK at short notice for me so perhaps later versions differ, better batteries?)
OK. Lets get this sorted and clear up any misinformation etc
When you connect to a 12 volt source, it merely acts as a charging circuit to keep the battery topped up. If you start with fully charged battery and connect it to 12 bolt power, then if the power supply is disconnected for any reason, it will continue to record until it senses a low battery voltage and it will close of the file correctly before turning off completely with no loss of video. If the battery was shorted or dead or faulty, then it would not provide backup power to allow for the shutdown, This safe shutdown has happened heaps of times where cars have been in accidents and have had the battery idolater pulled. In every case, it kept recording until the battery went flat and no video recordings were lost. This is the only system on the market that has an uninterpretable 12 volt supply option. This was particularly evident at the recent Bathurst 12 hour where Black Magis used 10 RadCams for their TV coverage on OneHD. All cars were connected to 12 volt power in order to get the whole 12 hours recorded non-stop at 720P on a 32 GB card..
If yours is not doing that, then please send it back and I'll find out what the issue is as it is certainly not typical.
Yep, and my tip for those using the system is to make sure that the 12V plug you are using is 100% compatible with the socket of the car you are plugging it into. When using the Radcam in my car I am not having any troubles, because its install-set and forget. But being an easy unit to throw in different cars, when using hire cars in Europe the silly 12v plug that goes into the lighter socket was not a consistant supply of power. Stupid thing would charge, and still whilst plugged in short (is that the right word?) the connection and whilst still plugged in the unit would then go back to its battery supply and if not checked battery would go flat. I use my car-mobile phone USB charger now anyway as it has this annoying big blue light on the plug so if the silly socket breaks the circuit its easy to see.
So i hope that explains why i found mine going flat....hardly a fault of the unit but something that can catch people out. So is something to be careful of if you are at a track day going from car to car etc.
Re the lost footage. I will throw the thing in the car over the weekend and just record whilst i am working on it to see what happens when the battery goes dead. Now that it is in my car i have not had any problems since the battery has never gone dead. Its only when its going from car to car that these things have popped up.
..oh and perhaps this discussion is best for the the camera thread?
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
