I remember being in the sad bus with Bill Pye in 2009 (Wrestpoint) and he was telling us he'd spent over $350K on building that thing of his.
Not to mention he has punted the thing off a 100 times, hate to think what the repair bills would be like!
I guess it keeps Grant in a job though!
....... and you got good money for it, so suck it up Princess!
...... and start building a GTS-t :D
Well a hug or a cup of harden the f**k up. Thanks woo. Have dried my eyes. All good. Really need to find out what all the fuss is about with GTST. :)
Was your car really 1100kg? someone said they saw it on my105
I will make no comment on the cosworth stroker crate motor but the car weighed near enough to 1260 at race weight. I weighed it after targa with a bit of stuff out of it at about 1245
Drive mine anytime mate.
They're fun to drive, cheap, quite quick, sound great, did I mention cheap? :)
it was a 3l cossie job wasn't it? :P
the bloke running round telling everyone it 1100kg is renowned for making stuff up
Ah, the truth is finally out there about the engine. :)
Yeah, he is definately talking shit. Feel free to pass on the pic of the weighbridge piccy below. Not tat it actually proves anything as the car isnt in the pic.(SMS's it to Snowy to wind him up) :) I think it weighed 1270 at THC when they put it on the scales. Have nothing to hide so would happily confirm the weight if it was 1100kg. In reality the time attack guys with fully gutted cars struggle to get to that weight. Dont hink I have actually ever heard of a 6 getting that light. maybe 1150...
and Woo, you had me at cheap :)
Hmmmm. I think i have some idea of where the 1100kg might have come from. My service crew may have been guilty of adding some grist to the tassie targa fraternity rumour mill. :) Apparenbtly there was some chatter about my car when it was for sale and Greg got queried on it. When asked the weight his response was something along the lines of "I cant remeber if it was 1100kg with or without the crew in it." :) Farkin shit stirrer.
Greg loves a shit stirr!
But I had it on good authority from a guy that knows a guy who knows the guy who built the motor and its definately 2.4 grunter.. well that was the talk sunday night at the bar lol!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
