Perana V8, step aside...
are these kind of shenanigans still allowed in Targa?
Yep good thing's, we have a customer with one of these LHD and all, AASA rule's allowed him to fit an LS1 and 6 speed
wild looking set of alloy arm's under the back of the thing..
I spoke to the chap with the Scarab at Baskerville about 12 months ago, I was quiet interested in his lhd 280Z until he lifted the bonnet to reveal a pushrod engine were once lived an L block.
And speaking of chook cookers still for sale now with new turbo freedoms fit a D9 dozer sized turbo and cook your chooks faster
Last time I looked at these it didn't work as Scrarab wasn't connected to Datsun in any way.
There were a heap built from memory though.
What you need is a good rotary.
How many Alex seals you blow while typing that :P
Ahhh,
soo much rotor love. I'm keeping my mouth shut as I am sure any tough talk on rotors will only come back to bite me in the arse when it self destructs at a really inconvenient time. :)
For your amusement....
I for one hope it all goes well for you Blaise and that you take it to the Porsches!
THC.... who's going? I'm doing "00" again, and will be driving up there Thursday PM with Captain Fathom, primed for festivities :)
Cheers Woo,
i really hope it works out, but gut feel is I had a pretty lucky run with the evo and it was a robust, reliable fast car. I think I might be out of my depth with the Rotor, but I do like a challenge. :)
For anyone interested, am collecting the shell this week. In the background I have been chatting to some people in the know about the suspension. We got as crazy as looking to graft as much of an FD into it as we could, but I decided that was WAY beyond our capabilities. Have scaled back to not reinventing the wheel and doing a V8 supertaxi spec live axle rear end in it and updating the front end. Go as light as possible and try to get a strong reliable 350 odd hp turbo rotor for it..... dreaming I know. Reliable and rotor dont really belong in the same sentence:)
Really wish I was coming to THC. The missus and I had such an aweosme time last year and are both a bit sad we arent there this year. Best of luck to all those taking part. Wlll be living the dream vicariously following it on the internets.
Edited by Darkside
I'm keen to come up for a chin wag at some stage but not 100% sure I'll be able to do so.
If I can make it I'll see if I can drag MrRB20 up and we can have some prelim discussions on Euro 2012 Woo.
You're not in Melb for any length of time are you in case we can't make it?
A few old Datto Z cars including Jon Siddens will be there for THC, hope they can stick it up a few 'non ABS equipped' Porkers. Well maybe they might have a chance against the 'budget', under $200000, ones :thumbsup:
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
