I noticed my heart was racing while watching it.... hoping nothing bad would happen.... but knowing it would.
It's a bit like hoping the titanic would miss the iceberg!
Your wipers still worked! You can salvage those!
Glad to see you guys were OK.
Thanking our lucky stars the embankment was there - would not have been much fun heading off into the trees.
No sticker on it as far as I noticed. The cage doesn't have a scratch on it - have asked Meridian their thoughts on salvaging bits of it.
Unfortunately my do it once, do it properly philosophy seems to apply to crashing as well! Will get some other opinions but things look to have shifted too much for a repair. I don't want to risk ending up with a compromised result. Would be looking for a no accident, high km full car, maybe import one as race/rally and sell off the bits I don't need.
The front left suspension tower has shifted down a fair bit after taking the initial impact. You can see the bend in the strut brace and ABS lines. Engine seems to have escaped unscathed minus the little fire that only looks to have taken out some wiring next to the turbos, no interference with the fan / balancer area. The radiator might even be ok.
Roof is buckled above drivers seat, through to the windscreen frame.
Rear left quarter has also dropped and the wheel is shoved backwards so the subframe is probably a mess as well.
One weird thing, can't see it here, but the passenger side floor checker plate is folded right over where it runs next to the transmission tunnel . . . transmission tunnel looks ok though - interested to see what the hell happened to cause that.
Not a hint of a bend or crack from the cage.
Your crash is very similar to how I crashed in Arrowsmith 08 (was even a R5>3), I was just lucky I fell into a ditch at slower speed, and didn't get any style points for a triple pyke.
You would be surprised how well they fix. Dad's R33 has had 4 big hits in the front left (3 by us, 1 by Glenny). We replaced the left front tower after our first hit, cause Glenny had a rushed job to fix it when he crashed, and it was no good after a second hit. The 3rd and 4th hits were fixed on a chassis aligner.
Your crash is very similar to how I crashed in Arrowsmith 08 (was even a R5>3).
Haha driver induced understeer of fail, it's how all the cool kids do it :thumbsup:
Well yeah could be a repair job and a front cut as Woo suggests. The metal guy we used on my 32 shell is a wizard - no doubt he would be able to get it straight again just depends on dollars. Once I get it back in Melbourne and up on stands I can get him to have a look.
Seems a good opportunity to pee-off(!) :rolleyes: those seats and get something a little better.....if somewhat inconvenient on transports. Teensie-tiny in-car suggests no HNR, going by the head movements....been there, done that, have the impressive array of X-rays!!!!
Cheers mate much appreciated. Might have a spot a bit closer to home but will let you know.
You said you always wanted to keep each racecar you built . . . new deal - you build and develop them, sell them to me, I crash them and bring you back the shell for your museum :P
God I watched that video with my heart in my mouth mate. So glad you guys are ok after what could have been SOOO much worse. The cage did an incredible job, worth every cent methinks. Sad to see my old car looking so hard done by, but it's only sheet metal!
Yes certainly worth every cent - Andrew will definitely be building my next cage. Will give you a yell when the dust settles about possible shell options.
Sad to see Paul, but glad the car held up well and is a testiment to both chassis strength and the quality of the cage. Shows how quickly it can all go wrong!
Hope you can get it all sorted and back to full health ASAP.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
