Wait, what?!?! Am meant to be updating my car's CAMS log book?!????!?
some of us don't have cams log books yet. If you have one your fine.
Dad's subie got knocked back by CAMS because they didn't accept an FIA spec cage from custom cages. But when he rocked upto High Country he got one, as the car ran under AASA Targa. Gotta love consitancy
Interesting, Skylines are not eligible for 2B or 2F as per this list: http://www.camsmanual.com.au/pdf/02_race/c.%202nd%20Category/RA18_Group_2B-2F_EligibleVehicles_Q411.pdf
But 2A has no particular/relevent restrictions except only 2WD can race, and they have to have 2 seats. So no reason that couldn't be it.
But you are in QLD so none of this really matters for racing, right? AASA race regs will chuck you into touring cars (super TT) and irace will put you into Jap/Muscle cars. Neither of which appears to have any particular restrictions, so get out there and give it a go.
If you want to race CAMS you are up against the porsches in sports cars. I am not sure about QLD but in NSW the state champ sports car racing is 2F which Skylines are not eligibile for (I am working on application though)
BTW all the dirt rally regs are also on the cams site for anyone who is looking at those classes:
http://www.camsmanual.com.au/04_rally_road.asp
These are the high level classes:
Group 3 - Club Rally Cars
Group 3C - Production Rally Cars (PRC)
FIA Groups A, N, R, Super 2000 and Super 1600 Kit Variant
CAMS Group N (P) Rally Cars
Showroom Rally Cars
Historic Rally Cars
Classic Rally Cars
like racing, there are non-CAMS categories like AMSAG
They just look too restrictive in terms of ability to move across to circuit racing to me. And I guess very few tarmac rally-ers also do dirt.
If anyone has run under a targa event in their car under AASA and is having dramas getting a CAMS log book, or is having difficulty in the cage certification process please all the targa office - there has been the odd situation like Brendon's STi that have required some event explanation.
Glad to see you're rebuilding so soon Paul. Was great to meet you at THC and i'm sure i'll see you out at future events.
We had an interesting THC, Dad had just recovered in time for the event. Managed to run several minutes faster overall than last year, still not fast enough though! Ended the event with the front brake pads worn half way through the backing plate and a car that was overheating and down on power. Hopefully will have everything ready for TWP!
Anyway here's a vid of one of the better stages for those that are interested. Watch in HD if you have fast enough internet...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
