Car handles the bumps on the fast bit at 7:45 well. Good setup lads. Lots of torque too it sounds like. Goin great guns!
Keep it up!
RB20 with Talk???? There is only one "Roy" that would believe that
Ben looked as good as anyone at Paloona yesterday.
Think Quinies Exit may have been mechanical rather than political
TT
What happened with Ben and Damo?!?! Dropped about a minute over The Sideling!? :(
Come on lads, you can make up the time through Longford! Time deductions for skids!?
FB says they had a fuel pump die.
All fixed now and back on pace!
You'd know if you hadn't become a Facebook outcast.
Apology accepted :P
And just quietly, how awesome is the old bugger Beable going! You've still got it Jeff! Cracking time up over Rossarden. Still hard to keep a good RB26 down :)
Keep up the great work everyone.
The lift pump started to fail at the morina start line, and got progressively worse. It was a fine line between loosing time, and melting the engine. We have replaced both pumps and are ready to go again
Apology accepted :P
Beable knows the roads so well and his car! Does Beable do any other motorsport besides Targa Tas once a year?
Going excellent Ben! Keep up the good work and stay safe! So cool to see you in 2nd place under Pritchard..Keep those Porsches on there toes :)
Well, it's no Evo **cough **stroker but she goes alright!
Looking forward to your Paloona footage Benji, good stage that juan there!!
C'mon Benny Strokers drive Nissans too... I always said those RB24s would be a good thing.
In all seriousness BM - well done. You have been a quite achiever for some time. Enjoy your 15min - it is reward for your years of disappointment. Old fella still going OK too
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
