Tarmac Rallying Perpetual Thread
Marlin
So heading off down the Hume again tomorrow for the second round of the "other" tarmac rally series at Lake Mountain. Sammy drove in round 1 at Mt Baw Baw where we placed third and with the aim of sharing the fun (happy marriage and all) it's my turn to drive.
Last time we were there all was going well till we melted a couple of pistons at 200km/h so there are a few scores to settle with the mountain. This time we're rocking the E85 and a brand new set of A050s (last time the tyres were 2 events old) fingers crossed it's enough :)
This year the event has expanded from the hillclimb format (12 runs of 10kms) to a multi stage event using the road from Marysville to Lake Mountain and Cumberland Junction with total kms of over 200 for the weekend.
Well, what an awesome weekend we had in Marysville. Seriously, I hope more people enter and attend Pete's events in the coming year/s as the level of social activity and camaraderie amongst competitors and officials is at a level you just don't get at any other event.
Until 7:30am on Saturday morning I had never driven the car in the wet so the shakedown run was just that, a great chance to get rid of the nerves and feel the car out on a road I knew well. Temperatures around the 4-5 deg mark, fog and rain all added to the challenge. Once into the swing of things on Saturday my aim was just to improve my times throughout the day and get the car home straight. Saturday was a success then :rolleyes: with times tumbling throughout the day leaving and after trading times (by as little as a second) with Clinton Arentz, we finished the day in third place.
Sunday was more of the same weather wise (albeit a little less wet and a bit warmer as well) but with different stages it was back to square 1. The first stage Sunday felt ok from the driver's seat but didn't feel special. It was enough though to win the stage by 4 secs from Denmeade (also stopping his clean streak of stage wins :3some: ) By the last stage Sunday I was really comfortable in the intermittent conditions and really had a go, finishing on a very big high! (second on stage and enough to secure third outright)
Unfortunately the entry numbers were low, but you gotta be in it to win it (so they say)
To top off the weekend we have a car that drives onto the trailer and needs minimal 'urgent' work, just little bits of maintenance :cheers:
Shame I missed it Dan. With moving house, fixing broken cars and being drunk too often I didnt get to enter the Touring. They are some great roads with plenty of runs. Shame they are still struggling to get numbers
The only thing in that list that doesn't generally happen at rallies is moving house (although when unpacking it certainly feels like it)
The roads with this new multi stage event were unbelievable with everything from flat out to tight and twisty switchbacks, even on the same stage. Would have loved to drive them in the dry but still enjoyed them regardless.
Here's some incar from the stage we won outright by nearly 4 seconds. Excuse the poor sound quality, we had an issue with the audio jack on this stage :(
  • 4 weeks later...
  • 3 months later...
We will be there again this year in this, see you in early modern!
Well you're going to flog us in that haha
Took it for the first shakedown the other night and ended up with this after half a warm up lap. Shit Bitsrmisn engines, luckily new one is already in the hole.
    • Great for thrashing on the track - particularly if it is all corners. Otherwise, it is a recipe for massive tyre wear and reduced straight line traction. -1 is plenty for a streeter.
    • There are other MAP tapping ports. There's one that runs to the boost gauge MAP sensor on the firewall (over in the corner behind the brake booster). Start at that sensor and follow the hose to the plenum.
    • Japanese circuits have always looked tight to me on Youtube vids. They seem to be able to fit tracks into the smallest of spots. I've never experimented with camber in the rear. I'm running similar front camber to you (albeit in the E90) but I've been looking into what options I have in the rear. -3 rear seems like a lot. Yeah, mine is the N54. I had an N52 330i for about 7 years, it was awesome but I just needed a little more poke. The N54 is also DI. I'm running BC coilovers with the M3 front arms and a Whiteline front sway bar and the turn in and ride quality is brilliant. But I do still suffer from a bit of roll so I've been looking into that lately.
    • Thank you for explaining. Makes more sense now. I saw that diagram but wasnt sure if the MAC solenoid would use the same plumbing. So I just did what the stock looked like. Ill get that fixed. I even saw this image As for MAP sensor, When I place vacuum line from MAP to stock location vac reference ( port by BOV flange ) the car runs like crap. I think the port is clogged or something, cause when I moved the MAP line to plenum and connected the BOV to that line, I get compressor surge. This is why I moved MAP vacuum line to plenum where BOV is. Where can I T the MAP vacuum? Sources Ive read said to let MAP vacuum be its own and not to T.
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime. The boost signal has to pass through the MAC valve from boost source (turbo outlet - effectively anywhere between the turbo outlet and the throttle body will do, but closer to the turbo outlet is best) to the wastegate. What you have done is connected it sort of like the stock solenoid. But it doesn't work the same way as the stock solenoid. That Tee piece that you have connected the solenoid to....? The solenoid itself serves that function. You should look up a typical MAC valve connection diagram for a single turbo internal wastegate application. You'll find one easily enough. Every single boost controller manufacturer that uses MAC valves will have one. Bugger it, I'll just grab the HP Academy one. The other thing you have to get right is that the boost source has to be connected to the correct port on the solenoid valve. This is because the solenoid makes the valve switch from connecting 2 of the ports when it is unpowered, to connecting one of those first 2 ports to the third port when it is powered. One inlet, two outlets. You will note from the diagram that the common port is port 3, the port to the wastegate is port 2, and port 1 is the vent (where the boost signal escapes when the solenoid pulses ON). As to the BOV.... the vacuum signal for the BOV simply has to come from the plenum. It must register boost when you're on boost and vacuum when the throttle is closed. That's all. The original location on the plenum is best. Best practice is never to interfere with the vacuum line running to the FPR. Just leave that one alone, as you will avoid causing unintended problems that might occur if you mess something up.
