  • Replies 144
Updated again
Bold shows changes from original ad
6x550 side feed blitz injectors in rb25 rail sold
r33 rb25det Power fc inc hand controller sold
r33 S1 RB25DET gearbox with custom 1 piece tail shaft suit r32, modified GTR speedo drive, slave cylinder and modded cross member sold
rb25 det engine loom modded to suit late r32gtst manual. Minor changes will be needed to suit stock afm (4 wires) and o2 sensor(3 wires). currently wired to suit z32AFM $250
GTR front drivers side guard with lip rolled and a small dent above the wheel arch, silver, $200
GTR front drivers side indicator $100
GTSt indicators, pair sold
GTSt front guards with compliance indicators, pair $300
rb25 ignitor $125
rb20/25 CAS $100
And the after market bits
Trust remote mount oil cooler sold
Xtreme XHD 9 puck clutch kit This is now an xhd pressure plate (1040kg or so) with an exedy full face friction plate that is near new. $250
Cusco comp coilovers damper and height adjustable front and rear 8/6 sold
Cusco master cylinder brace suit 32gtst/gtr sold
Whiteline 24mm front sway bar sold
rb20/26/s1rb25 splitfires $400
Trust type R bov sold
Just jap B pillar brace $100
Cusco castor rods bent $75 firm
Maltech braided brake lines ADR compliant $250
Just Jap adjustable front upper control arms sold
Stock front upper arms with nolathane adjustable bushes sold
2 Davies craig 14inch thermos sold
early model hks rb25det cams 256 8.8/264 9.0 inc adjustable exhaust wheel $650.
s1 rb25, no coils, no turbo no injectors. sump has a dent in it where it hit the sway bar but can provide a spare, runs well, good compression $1350
cheers
Dave
G'Day Mate,
Do you have the speedo Cable and the bit right behind the speedo itself.
If so how much. (Ill internet Bank it into you bank account immediately :-))
Postage to Tassie reqd.
Cheers
Brett
And again
r33 S1 RB25DET gearbox with custom 1 piece tail shaft suit r32, modified GTR speedo drive sold
rb25 ignitor $125
rb20/25 CAS $100
rb25 clutch slave $50
rb20/26/s1rb25 splitfires sold
And still no one wants some perfect condition hks cams and an adjustable wheel for cheap!
i do, It'll be hanging off the back of the engine somewhere.
I saw your wtb but figured it'd be quicker for you to get a new one local than me post down a 130k old one so left it alone.
The bits that are left....
s1 rb25det, no coils, no turbo no injectors. sump has a dent in it where it hit the sway bar but can provide a spare, runs well, good compression $1350
rb25 ignitor $125
rb20/25 CAS $100
plus a heap of random crap thats still got to be pulled out of the shell
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
