hi guys this topic has most likely been covered but can not find it on here or on the Vic roads web site
Q: Are gauges mounted in the A pillar legal or not legal will they pass roadworthy inspection any help would be much appreciated thx :down:
https://www.sau.com.au/forums/topic/230405-a-pillar-gauges-roadworthiness/
thx guys for ya help took 10sec for an answer here I've been looking for a week about this
I have a gauge that passed without mention. I'm not suprised they are illegal although I didn't even think about it at the time.
On the old skyline i had 2 gauges on the A-Pillar. During the major defect and getting the car re-engineered the guy sent a pic to the proper authorities and said that the A-Pillar gauges were legal.
If they cause no vision imparement out the windscreen its ok... if they do, then illegal....and since id say most people use the Greddy A Pillar thingy... most peoples would be illegal
i woulda thought that its also a crash hazard. imagine collecting a guage with your eye in a headon. yum
i can test that theory out for you
ive got a spare crap gauge here and we put it on ur eye adn smack it with a hammer :down:
i have 3 gauges mounted on the passenger dash....this is ilegal because if i have a smash passenger will hit all 3 gauges.....it just depends where you get the roadworthy i passed with these with 2 differnent roadworthies.....
sounds like a plan. you bring gauge and i'll bring the eye. ooh the next meet will be interesting indeed :down:
problem is the next meet i will be at will be in 7months
so u get to keep your eye till then you bastard :P
Its all on VicRoads website too.
Just look for the VSI (Vehicle Standards Information), can find it off the main page so pretty easy
Slightly off topic, but I had a taxi driver the other day that had his GPS screen just slight left of where he was looking out the windscreen. IMO they are a LOT worse than any gauge can be (except a 5" monster tacho on the A pillar as seen on some civics and bombadores).
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
