I'm Goin For A Drive *sunday 7th September*
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 186
Posted Images
Updated list - shaping up to be good, as the big man would say himself "im excited"
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink
9. Sky33t
10. zcr
Well actually he would have said "I'm excited", but he can't because he died from a heart attack because he was "big" Kev. Ironic really.
Anyways, I'm down for the 7th and so is 100% of others so it seems.
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink
9. Sky33t
10. zcr
11. Michele & Mark - I'll just have to bring a photo of the open wheeler so she doesn't feel left out.
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink
9. Sky33t
10. zcr
12. TiTAN
Ay guys lets get all the act on this one, up to 14 people wow
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
As long as the cruise route has no hills and you guys dont boost it hard (my 40kw of Toyota power is lacking), I'll go in the 28 if im welcome (at least dattos Z has an RB in it :banana:), so lonely since i sold the skyline haha.
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
And now its 15
This is looking nice! The group photo on the steps of Old Parliament House is looking bigger and bigger :P I'm lookin forward to catching up with all you guys and girls.
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
17. TURISMO
18. naughtyruski
I'm going to lock this in for the 7th.
I'm in if it is to the north or west, too far on a sunday for me if it is to the east or south. So once you decide on the direction etc, I'll confirm.
Yeah, like Titan said, we'll probly finish up south west but it'll depend on where we decide to have lunch. I'd be good to see you again, I think the last do you came to was the dyno day, pluss I want to talk bikes with ya. ;)
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
17. TURISMO
18. naughtyruski
19. SteadyEddie
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
17. TURISMO
18. naughtyruski
19. SteadyEddie
20. a20089 (for even numbers sake)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
