Well, i have finally decided and put a deposit down on an engine conversion kit for my N/A R33, I will be getting the engine from Just Jap, and with 31,000Km's on the clock, i think that i have done pretty well ;) , the only problem is now i have to wait!!!!
The half cut is still coming in from Japan and will be in Sydney in a few weeks after that, it needs to be pulled apart and freighted here :)
Anyone in WA ever done a conversion?
Also without an LSD will i be missing out on much, and with the rear hubs not being changed (from 4 stud to 5 stud) will this be an issue (my rims are 4/5 stud type rims so that doesn't really cause an issue), should i just by the rear hub assy, and brakes to keep it consistant with the front?
Thanks, pretty excited, but won't be excited until i'm behind the wheel of my car with the new engine.
Kris
https://www.sau.com.au/forums/topic/23138-na-to-turbo-conversion-the-big-move/
yes well that may be true, but back when i got my GTS i could not afford insurance. Now i can but have loans outstanding, and rather than sell my car (which i have tried and failed) i thought i might convert it, it gives me something to do, and i like my car anyway.
Guest neoGT-25
Hey all, a south-east queenslander here :)
congrats on the -t to your gts skyliner33wa :)
ummm... i have a non turbo R34 right... i want to get me a R34 GTT 1/2 cut in a few years but my friend was giving me an idea and i dont know enough about it to consider it seriously... he was saying if i got a rb30 bottem end and added a rb25det neo head that i would pretty much have a rb30det neo... is this concept right or wouldent it work??
sorry to theive your thread :)
thanks guys, well yeah i and my sisters boyfriend will be doing it, so labour will be free which is cool, i just want a standard GTST fro now, have always wanted one now i have made the move, i know that its gonna cost me alot but you only live once, plus i'm still young. I am getting the rear Hub Assy so, all i am missing out on is the LSD, i don't mind
Thanks
Kris
i was thinking of doing the same thing with my n/a but have been told by most people that its a lot easier 2 jus buy a GTST because ill have 2 change the engine, brakes gearbox blah blah blah and it will take a long time
also just wondering wat does it get insured as? a modified GTS? or a GTST? and because it wasn't originally a GTST does this mean that insurance will b higher then a GTST?
well, cause me and my sisters boyfriend will be doing it labour will be free, yeah it would be easier to buy a gtst but i can't afford it, plus i wanna do my own thing, about insurance, havn't really found that out yet, but i will tommorow, got an insurance broker i'll go thru
  • 6 months later...
Hi,
just interested to know how much it cost for the engine and parts etc, i will be looking to do the same thing in a year or so and want to know as much as possible before i go ahead with modifying my GTS..
also just a thought but for the same amount of money, is it just easier to get the same amoun tof power or more from the RB25DE?? leaving it N/A?
:rofl:
this would be a perfect oputunity to do a rb30det conversion insted, pity you have already purchased the front cut.
You should really ask these questions BEFORE putting money down.
werd.
for those talking about turbocharging an NA, and who havent yet committed funds, get yourself to the induction performance thread on this site and read about Rb30dets.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
