Just recently i fitted some DBA gold rotors to my 32. but i think i made ther mistake of using Bendix Ultimate pads... the squeel like a garbage truck!!!
is there anything i can do to stop or even just minimise the squeel... i heard something about copper grease, aparently it helps?
any ideas?
cheers
LOL!
I think you might have bought 'Race' brake pads and the probley have a bit of steel in them, which is why they squeel.
I drove a GTR before with 'Race' pads in and it takes a race track to warm them up and not to squeel.
Do what Blind elk said and see how you go.
they rnt race pads they are definatly bendix ultimate ...
how do i bed the breaks .... ?
well....did you read the instructions or the box you got the pads in? all pads have to be bedded in properly that is a major cause of squealing if not done properly.
since you've already put some klm on them....
pull the pads out
take the current surface off them using a bench grinder or similar
clean the discs and pads with brake cleaner
put them back in
head out to a nice quiet road, do about 3 stops from 120-40 until you can smell them cooking. then drive without using the brakes for a couple of minutes to let them cool
done. your pads and discs are now set to each other's shapes.
if they still squeal after proper bedding in you may need to try:
putting the anti squal shims back in (you kept them right?)
anti squeal compound on the shims
machine the discs to make sure they are nice and flat
copper grease on the backing plate where it touches the caliper's pistons
rebuild the calipers with new piston seals.
road pads including ultimates do not squeal unless there is a problem. even most race pads are fine. for instance the ones from my avatar don't squeal and as you can see they are pretty agressive.
Alternatively you could just go to the track :(
I recently put on a set of Ferodo DS2500s and they were squealing like a bitch. After a day at Wakefield they haven't made a squeak since. Although Duncan's solution sounds a lot safer than mine
Same thing happened when I put my Project Mu's on. I went out to bed them in with a similar process to what Duncan mentioned but they still squeeled a bit.
Went for a long night in the hills, and they were fine :)
i got the same pad. never had a probelm with squealing. if u bed the pads in properly they will last a long time.
try goin for a nice long drive and dont brake hard just ride the brakes + down gear at the same time to stop for the first 200kays and u should be fine
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
