I WAS DOING SOME FIGURES ABOUT THE LEGALLITY OF PUTTING A Q45 INFINITY MOTOR INTO AN R32 THE GTR V SPEC WEIGHS 1500KG. WHICH MEANS A 4500CC. MOTOR COULD BE PUT IN. I HAVE A Q45 MOTOR BOX AND DIFF 3.6 I HAVE DONE SOME MEASURING AND THINK IT WOULD FIT. THE ADVANTAGE OF THE MOTOR SWAP IS TO GET 550KW.MIN. AT A REASONABLE PRICE ,DOES ANYONE KNOW OF SOMEONE WHO HAS DONE THIS AS ALTHOUGH I HAVE GONE INTO MOST DETAILS EXPERIENCE OF A FINISHED PROJECT WOULD BE OF HELP.
https://www.sau.com.au/forums/topic/23287-v8-r32/
  • Replies 70
THATS RIGT ROY I ACTUALLY HAVE THE MOTOR AND BOX SITTING IN THE ENGINE BAY AND THE CLEARANCE TO GUARD TO WHEEL IS SIMILAR TO OLD MOTOR I DIDNT MEASURE IT BEFORE BUT IT LOOKS OK .I THINK THE 32 CROSSMEMBER IS GOING TO GO BLOODY CLOSE TOFITTING IT THE EXHAUSTS ARE GOING TO HAVE TO BE CUSTOM EXTRACTORS BUT WHEN YOU SEE THE CHOKING OF THE STANDARD MANIFOLDS YOU SEE WHY THEY PICK UP POWER SO EASILY WITH A BIT OF FIDDLING IT MAY ONLY NEED A SLIGHT BONNET MASSAGE FOR CLEARANCE .AS FAR AS BANG FOR BUCK I FEEL FOR LESS THAN THE PURCHASE PRICE OF A N AVERAGE 26 THIS WILL LEAVE IT COUGHING. THE STREET MACHINE SKYLINE DID A BEST OF 10.8 LAST NIGHT ,ON RAY HALL PUNCHING IN CONS.550KW. THE 4.5 SHOULD DO 10.2 I KNOW WHEN THE FLAG DROPS THE BULLSHIT STOPS ,BUT I RECKON ITS GOING TO BE A WEOPON.
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-498680
Mate of mine is doing this in a Silvia. Motor is in the engine bay now, requires no modification to firewall or strut towers to fit. Needs a fairly elaborate crossmember and gearbox mount, but its do'able.
He has gotten approvals from transport to do it, however he has to have it all signed off by an engineer and have it brake tested before it will be registered. He spent a VERY long time researching it and discovered that just about ALL nissan engine bays have very similar dimensions, plus crossmembers are pretty much all the same (apart from the 4wd vehicles GTR etc.)
The difference in weight between the VH41DE and the CA18DET is about 50kg. The advantages of all alloy :stupid:
Red17
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-498704
A Q45 powered Skyline would be something I would particularly enjoy.
Deep down I do not like turbos. I am a knuckle dragger at heat liking Corvettes and TVR's and the like.
If someone can shove a 4.5 into an r33 GTSt, I'd like to see it.
I would not do this to an r32 GT-R V-Spec though...
T.
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-498731
Originally posted by Soulja
ANDY32 go for it!!!! putting a v8 into a skyline has been a dream for mine for along time. v8 turbo set-ups can put up 2 1000rwhp very easy!!!!!!
Eddy Tassone's made up to 1500 rwhp in his VH Commodore.
Twin turbo 6.3L (383cui) Holden 5L stroker. F$%kin' awesome...
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-499692
TonyGTST, from what I can gather, ANDY32 is not putting the Q45 into a 32 V Spec, but because the heaviest of the 32's was 1500kg, you can transplant that engine into ANY of the 32 series Skylines, therefore allowing you to go for a clapped our 32 GTST for nix to use as the donor vehicle.
I know a guy at TTR in Brisbane who has a quad cam v8 in a Silvia also, but he is having problems with the legalities because of weight issues too.
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-500163
UNFORTUNATELY TO TURBO IT IS OUT OF THE QUESTION AS YOU ARE ONLY LEGALLY ALLOWED 2.5 TIMES BODY WEIGHT SO MAX. CAPACITY WOULD BE 3750CC. AND YES YOURE RIGHT I AM NOT FIDDLING WITH A V SPEC. I HAVE TALKED TO SOME ENGINEERS WHO PUT THEIR YES ONTO MODS. RE;SILVIAS WITH A Q45 WITH MIXED FEEDBACK SO IT WOULD CONCERN ME IF I HAD A PRANG IN A SILVIA HENCE R32 AND PERSONAL OPINION ONLY, I FEEL THEY ARE CLASSIC SKYLINE SO ON THAT NOTE I WILL SAY G00DNIGHT
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-500570
NO FOR A 33 THE ENGINE DISPLACEMENT WOULD BE MORE AS ALTHOUGH I HAVENT RESEARCHED INTO IT I THINK THAT A 33 TOP SPEC GTR WOULD WEIGH MORE THAN THE SAME 32, IF IT WEIGHED 1540KG? THEN YOU COULD PUT A 4620CC. NON TURBO OR A 3850CC. TURBO.I CAN ONLY SAY FOR QLD. AS I HAVE NOT LOOKED AT OTHER STATES.
https://www.sau.com.au/forums/topic/23287-v8-r32/#findComment-504461
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
