cheers mate
no doubt i'll give you a wave if I see your ride around as I haven't seen any lakeshore blue v35's either. i don't tend to see many v35 sedan's come to think of it.
i probably won't be lowering it anymore as it's already scraping over speedbumps...i wince in pain every time i drive over any surface that isn't level.
hey guys.. finally upgraded from the 34.. although i miss all the power !.. mines a dec 05 premiem spec.. already removed are the factory alarm sensors on dash , toll card reader , and a few silly things...
Mods done - X force cat back 2 1/3" mendral bent exhaust same as 350z except it needs 25cm added to extend it
full nismo kit from japland
20 x10 with 275 rear and 20x 8.5 235 front koya visso, viper pager alarm
Next to come once chris rodgers has converted my bose dash unit a full 7k stereo and some springs to level the car out..
See you fello skyline owners around
Edited by 53XYN
very nice ride you have here, very beautiful, and beautifully kept.
Your project, should you choose.......let's get that rear number plate nice and straight......??? :P
ps...I just came from an R33.....sure I miss the launch/noise of that thing....but not the 'power' as such...V35 has so much more low-down torque that it made my R33 feel a bit 'small'......I can leave my V35 in 3rd gear most of the time! (and I live in the hills)...R33 was always wanting gears...(still loved it though)
Got dish?
Geeesh!...they are horn looking cars.
I like your dish....(got dosh?)...
They're not overboard, which many seem to be going towards,..I like them very muchly.
Our cars look the same, except mine hasn't got that front wheel mud guard thang....(and got std 18" rims, which I love too muchly to swap over).
Hi all: I'm not new to the site: have been floating around in the Stagea section for quite a while now...
I bought a pair of manual V35s close to 7 months ago: one sensible car, and one silly car. They are now, finally, complied!
As I am yet to take pics of the sensible one (haven't had a chance to clean it yet!)here is the silly car: it is the Chargespeed workshop car for Tokyo Auto Salon '07. It won a trophy in the 'sporty car' category for its body kit. The car is factory standard mechanically, with the exception of the 19" wheels and Advance coilovers, so it's a complete show pony as-is. I intend to keep this one (i think), and add the HKS supercharger kit, for a bit m ore poke. Also, the carbon fibre seats are a new lesson in torture (made for narrow japanese rear ends), but I have a pair of Recaros lying around that I was going top put in the Stagea, so I am considering fitting these after a retrim.
Alternatively, I could put the SC kit on the other car, which is immaculate, and only has 10800km on the clock.... I'm torn! The wife says I have to sell at least one of them, but I don't know which way to go.
Anyway, here's some pics of the kitted car finally in Australia and complied:
As soon as I have it on the road, and cleaned, I'll post some of the other (sensible) car as well...
  • 3 weeks later...
  • 3 weeks later...
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
