Hey guys,
Finally got tyres for my rims an they are now on . I'm loving them, tell me what use think???
19x9.5 +17 fronts 245/35/19
19x11 +10 rears 275/30/19
Look good! A full side shot please. Are those Intensive Hunks? Needs a bit more of a drop me thinks to get the full effects of those offsets.
will get more pics when sunshine/time allows, Only on stock suspension atm.
Suspension is next on the cards, Yep you're correct intensive hunks they are :)
Cheers.
The infamous Chris Rogers supplied and fitted the shark fin antenna as part of the TV tuner install. Reception is pretty good in most areas but still not perfect (obviously).
I would have liked it if the fin was a little shorter or less pointy. Finding a suitable replacement is high on my list of things to do in 2010.
And yep... phillip island on sunday. First time actually.
Hey Bee!
Spotted you parked in Jacaranda Estates! Was taking a walk there as I live in Jacaranda Heights further inside...what a coincidence! I remembered your wheels lol. They definately stand out!
Hey Bee!
hey man,
lol if you saw it parked on the park side that's where it lives coz i really hate my driveway hahaha.
Yeh i figured you lived further in more. They really do stand out, it's either the chrome/dish
or that its sticks 1inch out of the guard lol
nice 35 you have there ... should go to test and tune sometime arent many 35's you see on tracks.. heres a few of mine at the SAU drags
manages best time of 13.98 with constant 14.18 runs
at least it was fun spingin the 275 20's up lol
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
