a tad....a very slight tad, you'll also be surprised how smooth it is. i didnt compare the engine though. although for a $150k car it is rather dissapointing at only 200kw. but then again its a merc
They are a beautiful car. My brother-in-law has one a 2007/2008 model. Yes they are very smooth, but comapred to the V36s they are underpowered.
how much the v36 sedans worth if u buy local or would they be cheaper to import?
In Perth from dealer, you can get a decent sedan from $35k-$49k which is cheaper than coupe. I think you save about $4k-$5k if you import it yourself, not too sure.
They are really nice car, inside and out. But I don't think it is too good with resale.
Some of mine from the Extreme Horsepower show here in Adelaide last weekend .... and I picked up the "Highest horsepower 6cyl n/a" trophy for my 148.6rwkw dyno run.
53641B95A3AF4899A7EE0779A340CFA1-0000327810-0002006430-01024L-BE6629F164724D4297627648E40855E7.jpg
BE3E4BB452EA4111ABA7F1D52E7F022A-0000327810-0002006435-01024L-167ABE17A31A490ABC58D7F0374D95A4.jpg
More pics of my car and various cars in the show here (click)
^^^ and I should add that the V35 is my daily/work car (I am a property valuer) and I did a 750km round trip from Adelaide to Marion Bay and back (including 100km of dirt roads) the day before the above photos were taken :D .... and did a similar Yorke Peninsular trip the week before covering just under 650km round trip. Amazingly comfortable car to drive and handles the nasty country roads at 120km/h with ease.
im pretty sure thats a low reading...some boys here are running 155-165 rwkw stock...i swore i saw heaps of thread before.... :)
Andrew ur car looks sweet man. Props. I like that little trunk lip spoiler u got going der, wer u get it from?
Aslo yes have to agreee that that dyno reading seems bit low. Heard most stocks are round the 160 rwkw mark. Have u got any performance mods?
I got the rear lip spoiler off USA Ebay - cheap as chips and painted the KH3 proper factory colour
http://cgi.ebay.com/PAINTED-INFINITI-G35-G...=item2a0a8391ab
Regarding the power, there are dynos, and there are dynos. At Willall Racing, which has a Mainline dyno and is know to be conservative, I made 146rwkw 6 months ago. Then on the weekend on another Mainline dyno at the show I made 148.6. Most dyno is Aus are Dyno Dynamics, and are known to be a bit generous with their readings. There is also a ramp up and Z factor that the operator uses when dynoing a car, and if these are not absolutely identical from dyno to dyno then the figures will be different. You really need to have car on the same dyno on the the same day to compare cars. when we recently had a dyno day at Willalls some of the guys making decent power in their R32GTRs (350rwkw) were varying by up to 30rwkw between the dyno the car was tuned on (DD) and Willalls dyno (Mainline).
My mechanical mods comprise a stainless Greddy copy axle back exhaust, HKS panel filter, Carbon fibre Z-Tube and that is all, so she is pretty stock. Am fitting a Kinetix plenum cover and polishing my upper collector shortly, then will get rid of the very restricive centre muffler and fit a Y-pipe I have in the garage waiting to go on.
I really want to get another V35 on the dyno the same day as mine, and will arrange that in the near future for reference.
I also noted on my dyno printout that my afrs went down under 11.5:1 at peak power, so she is running pretty rich. I have an SAFCII sitting in the shed that I will get around to fitting in the near future to clean up the map a bit.
I might make a new thread with my dyno printout and get everyone else to put theirs up to compare. Interestingly the torque maxed out very early and fell right away as it made more power - not sure if this is normal or not.
Alrite fair enuf. Ders a thread up bout dyno results. With images of the readings and evrything. il try to find it.
Yes im after a rear lip spoiler, im getting rid of my oem one and tryn to get a boot wid a lip attached or molded. If only i was able to get hold of this one:
That is absolutely orgasmic! Do U know what rear bumper that is Steve?
It is bro. Dats the chargespeed rear wid the cf rear diffuser. Im getting that rear but i need to save up 1st as i still have a lot of expenseswid my wheels ariving late this month. The trunk is called a doriluxe trunk but is only available in the U.S
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
