  • 4 weeks later...
Here is my BOY. I just love it. I was actually planning to buy a coupe, but couldnot find one at that time. :thumbsup:
Welcome to SAU, Ahmet.
Sedans are a good choice too, more convenient daliy-drive. :)
hey people seen all the other v35's on this forum i think they are all fantastic. Just wanted to show u my v35.
post-80033-0-52856800-1298374271_thumb.jpgpost-80033-0-32025500-1298374367_thumb.jpgpost-80033-0-31425600-1298374443_thumb.jpgpost-80033-0-21832200-1298374571_thumb.jpgpost-80033-0-76150700-1298374696_thumb.jpg
Welcome to SAU, Rob.
Very JDM! :) Are all the black parts wrapped or painted?
Edited by Victor.T
Hey Liner
Can you tell me where did you got your Volk GTC and are they face 1 fronts and face 2 backs.
What are the offset and are they 19 x 8.5 front and 19 x 10.5 rear and with 245 front tires and 275 rear tires
Thanks for the info..
If you ordered them from Japan can you tell the importer and if here in Oz which company
Pics here haha
5522771136_94f30d2a84_b.jpg'
Whilst I like the overall look of this car, I completely don't get why people would lower a car so much to get the mean stance - but then paint the bottom 10+cm of the car the same colour as the road so it actually looks like the car is riding high like a 4wd. Just don't get it. It's like on R34GTRs I love the front and rear lips colour coded to the car (rather than black), so they LOOK really low, as well as actually BEING really low .... my 2c
Ah if it is carbon then all is forgiven :)
And yes Paul, black cars NEVER look as low as they really are sadly (and I would know - I own one). I scrape on every single speed hump and spoon drain, yet my car still doesn't look as low as I would like it - whereas my old pewter S15 wasn't even that low, yet looked slammed. But that is black cars for you!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
