Hi all just found SAU and this forum and would like to share.
here is my journey into the sunsets with my 35
add Impul bodykit
add Impul exhaust
and Greedy Coilovers
to
add wheels
and into the sunset
with my old R34 [anyone wanna buy a R34?]
Edited by spencer?
  • 4 weeks later...
Looks really good. Did they repaint the whole car?
Finally!!!!! the day has come, that the hail damage has been fixed and will now be able to show my face at meets! haha
only took 13 months for the parts to come in!
now i can start spending some cash on her :) :)
Just a quick play with 3D. You will need the coloured glasses on these. The Green Magenta are the best of the batch.If you dont have glasses, youll have to squint really hard pinch.gif
1st one you will need Green-Magenta glasses,
2nd One will need Red-Blue (the most common I think)
3rd Requires Cyan-Red glasses.
It was done using a standard (phone) camera and a trick, so its not the best.
Drove up to Geraldton in WA over the weekend, stopped at the Pinnicles (Google search it if you want to know) on the way back and this is the first time that I have taken any shots of the car.
Spewing i missed ya
Considering we have never met before and all I know about you is that your name may/may not be Paul, its pretty normal that you would have missed me.
I live in Gero. I have the only V in town.
Would have been nice you see another one
Ok Gotcha. Couldn't see you location when looking at the forum on my phone.
It was mighty quiet up that way, but I did have some fun blowing away some Falcodores when overtaking, on the way up and back.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
