Looks mint, any mods planned?
Thanks mkn. At this stage not really, probably have cruise fitted, get the nav conversion to english maybe a full cat back exhaust but im actually really enjoying the car the way it is!
Look great! Love the V36's in silver; they look so good!
Thanks GFXman yes the silver looks great and has some nice metallic it was either this one or a white that o was going to get :)
Another Adelaide boy.
Got my '03 GT about 4 weeks ago.
Loving it.
I had the front windows tinted to match the privacy glass.
Fitted 285/19/30 and 245/19/35.
Im happy to chat with any locals who are interested in sharing their secrets.
Im a complete newbie regarding the GTR.
My last grey import was a TT Soarer, that unceremoniously ended its days at Mallala!
That was back in about '04.
Remember there is NO INSURANCE on the track...
Edited by Ommadawn
I dont want to talk about it...
However.
'Twas a track day for the ALSC (Australian Lexus Soarer Club)
I had been there on about 3 other occasions, so was sort of experienced at track work. (I thought...)
We usually picked a practice day. Turn up with $85 and a helmet and it was ON!
Usual format was 15 minute session, followed by 15 mins bikes, 15 mins karts, 15 mins open wheeler then 15 mins cars again.
Would get about 3-4 sessions in a day.
Mallala is VERY hard on tyres and brakes. Its all Go real fast then almost stop to corner then go real fast again.
I was on the back straight (which has a bit of a dogleg in it) doing about 170Kmh. I was just entering the slight RH dogleg when I saw a Boxter wanting to pass, so I moved left slightly and waved him through.
Just a bit too far, got 2 wheels off the track and it went off line sideways, then back onto the track sideways......flicked the other way and spun out across about 100m of grass into the wall.
I walked away with a sore back.
Soarers are damned tough.
Damn that sucks. The main thing is you walked away :)
Luckily I haven't had any dramas like that in my little MR2; just a few spins on turn 1 getting a bit over enthusiastic haha
What sort of times were you putting down in the Soarer?
Yes, good to see another forum member with a V35 in Adelaide :) Welcome.
I have had my 35 out at Lala a couple of times - best time in it was 1:26 with windows down, music blaring and a/c on - it was a hot day! Followed up with some decent single pegger doughnuts on the burnout pad at the end of the day too :ninja:
My first time out there in the 35 I was being trained by Terry Bowe (John Bowe's brother) on a Bowe Drive Day. Terry put the 35 off the end of the straight/hairpin when the brakes failed due to being too hot (stock auto brakes with crappy fluid)- was not my ideal way to be in the passenger seat of my own car when I had only had it for 3 weeks. Bought some 350Z Brembos with Stoptech 2 piece floating rotors and Project Mu pads saw a fix to that scenario.
Best time in the Soarer was 1:30.3
It was a heavy car. Only changes were braided brake lines, Dot6 fluid, drilled slotted discs, greenstuff pads, soft compound tyres, shift kit, lowered 25mm and fluffy dice.
Its is an easy place to run out of brakes.
I just run out of talent....
Car looks great :)
Hah, you have the same wind deflectors I had. Recently took them off and plastidipped the chrome trim. Liking the look.
You will soon learn to hate black... don't think I'll get another black car again.. its always dirty :(
Car looks great :)
The factory optional wind deflectors are rare, and I like them!
I'd love to see your plastidipped ones Julian.
PS: I've spent the past 3 months emotionally preparing myself for the never-ending dustiness that comes with owning a Black car.
I think I'm ready now.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
