  • Replies 174
Posted Images
D'oh! poor fellas. on the bright side at least he hit the cheap end... :P
I didn't even know it had started yet!!
be carefull the rest of you boys (and girl) :kiss:
ps. the 'girl' is russ...
They still ra nthe Shakedown but were only allowed to run up the hill, not down and then up. it's claimed a few cars over the years that tree. Both 35's were looking do today through both stages i did. Ben and Russ really seem to know how to push the car, going very hot into the chicanes too. caught up with them after the competition today, 2 of the nicest blokes you will ever meet :-)
Ben and Russ has a minor off today, and the running-people-over bonnet popped up. Looking at the car you wouldn't know it had been off the road (now the bonet is back down). Appart from that they are going great, just wishing for r comp tyres, the std ones are quote "shithouse"
hey you know that they've been trying when they have to get pulled out of a ditch.
Kel and Tony are in 6th, still not really happy with the tyres or handling either but at least they are giong a long way better than at Targa.
Is it still going to be wet tomorrow Ben?
Toyo are supposed to be releasing an R Comp (R888's) for the R35 at the SEMA motorshow in November apparently. I must say I've never thought the Toyo's were much chop on heavier cars like normal GTR's but given these were pretty much specifically designed for this car for the US market they might be ok (and surely will be better than what the options are now).
Anyways despite the small issues it sounds like from the text mssages that the boys are having some fun so thats all that matters.
There are a bunch of Evo 9s kicking around in the country with Ralliart TMM (Team Mits Motorsport) style stickers.
Different one from Targa roll over.... that was Rod Salmon
My car, I sold it to Rod
Good stuff....Kel ended up coming home in 5th which I reckon is a pretty good outing.
Rus and Ben also made it home (9th) although I hear there were a few white post casualties on the last stage - then again who hasn't knocked out one or two of them :wacko:
And funnily enough the DK R32 came home equal 5th with the DK R35. I guess the old nuggets still go OK too.
