hey i'm planning on doin some track days soon at QR, and my mechanic said that i should consider puting a baffle in.
he said its borderline requirement for street tires/brakes, but better safe then sorry
i haven't come across this before, and considering its a fairly big job puting one in i'd like to hear some opinions.
https://www.sau.com.au/forums/topic/234340-sump-baffles/
probably a good idea. trust you mechanic as this is what he does for a living. he, will end up getting a build out of it if you dont do it so either way he is getting work. rather spend the $1000 fitting the sump than a couple of grand re-building engine and still having to buy sump. not hard to replace sump in the car.
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4106265
very true^^
with the gtr the engine has to come out to do the sump, probably worth doin a N1 oil+water pump at the same time yeah?
or the alternative is to get a dedicated track car and work that, to save the wear and tear on my streeter
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4106287
This has been dealt with at length a number of times. Maybe try a search.
But in the meantime some things you may like to think about.
1. You need to remove the motor to fit sump baffles.
2. If you upgrade the oil pump you may as well fit an oil restrictor to the head.
3. To fit an oil restrictor you need to remove the head.
4. If you are doing that you may aswell rebuild the thing......
But he last. most important point:
If you overfill the sump with oil you will not suffer from oil surge & the motor will be fine.
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4106350
yep...trent
i agree with djr81 once the engine is out all sorts of things to consider.
if you keep a good close eye on oil levels(overfull) , then you should not have a problem, except maybe some breathing depending on mods.
keep a good eye on engine oil temp and coolant temp though!!
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4106756
my advice. spend the money on a top quality oil cooler kit. use good oil (motul chrono is hard to toss) and maybe overfill a little (personally I think 1l is too much, but it's up to you). also get a decent oil pressure guage with warning and recording feature (this way you can start it recording, do 2 laps, come in and play it back and watch to see if and when oil pressure drops it shoul be above about 4 bar for 90% of the lap).
my logic is those things will be needed with or without a built motor so doing them no does not cost you anything. I figure if you are running under 300awkw you 'should' be ok.
the other guys are right too, given the big labour cost in removing and re-fitting an engine it makes sense to do it along with lots of other gear which really blows out the cost.
edit: your mechanic is spot on though, sump baffles are a very good idea in any track driven GTR but the cost is just a little bit prohibitive.
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4107043
I've just gone through the same condundrum. I run 300RWKW and have just done a track day at Phillip Island. I spoke at length with my mechanic who said the sump baffle is a big job and not necessary for what I'm doing (sprint work / track days / fairly std brakes and R specs). I'd still like one though, but perhaps next time the engine is out (not soon I hope)
They changed my oil and overfilled my sump by 500ml. I run an oil cooler and have a large after market alu radiator. My main bearnings are machined for extra oil flow around them too.
It pulled like a train all day and the temp gauge never moved - and I never lost oil pressure. The car came home happy.
p.s. I have my beautiful new engine as the last one went pop at a track day, so there is danger without adequate precautions. The track is a stressful place.
Edited by LotusGTR
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4107091
thanks everyone for your input so far
i agree with you guys in that fact that if te engine was to come out, it would recieve more than a sump, which =BIG$
what sort of oil pressure guage's have recording features on them, beer baron?
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4108618
I use Defi BF oil pressure gauge. very good. since I have the defi BF oil pres, oil temp, boost and fuel pres. they are very useful. You can adjust the warning level for each gauge, and there is a buzzer and light for each warning. and it can record the movement of all gauges. after 2 laps I pull in and hit play. you can tell when you are on the brakes or cornering as the car is off boost, pay close attention to oil pressure in these moments to ensure it didn't drop too much. if all is well go out and enjoy. I also run a big trust oil cooler and the filter mount it comes with has lots of handy points to install the defi sensors. they are a snack to install DIY too if you like.
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4108932
i'm not really a "guage" person, they look good tho :P
will the standard oil pressure guage respond quick enough to detect no oil circulation, although its a little hard to see when at full tilt + no warning buzzer
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4109801
Unfortunately the factory nissan guages are poor at the best of times. you can purchase an oil pressure warning light and sender that will come on at 30psi. if this comes on when your up it you have a bit of time to get out of it and reduce damage. by the time your factory guage reads and the 0psi light comes on its too late.
i'm not really a "guage" person, they look good tho :D
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4110957
i'm not really a "guage" person, they look good tho :)
the factory gauge is rubbish. it's an idiot gauge. it's very slow to react (so as not to alarm the average joe) and not very accurate either. if you install a proper gauge you will be shocked at how rapidly oil pressure varies with revs (as it should since the pump speed is directly related to engine RPM). it moves about the same speed as your tacho! if you don't want gauges the warning light is an option, or some other kind of data logging, but the simplest solution I found was just fit a proper oil pressure guage.
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4111298
i like the look of the apexi EL2 guages, they are run from a controller like the defi's, and have record, replay, warning system.
i just think it'll look a bit "VN bogan" having guages everywhere.
please post some pics of your set up, i'd love to be proved wrong
EDIT: whats up with all the harness and sensor options? both apexi and defi have a massive list of options, i would assume they're for the digital display unit?? OR do i have to buy the guage AND the harness?
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4113152
if you have a big f-off oil coller over fill 500ml
if you dont ive run up to 2 litres more (wise man once said the notch in the dip stick.. that stops all surge i find defi proven)
never spun a bearing
but im not like the rest of these clowns on here.... i generally dont rev the old girl abouve 7500 at the track
i would add more if your reving harder and dont have restrictors
take 500 mls of the above instructions if your car is a gts and rwd
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4113360
ohhh as for quality oil in a 15 year old rb26
lol
castrol magnateck....... thick and creamy for those old engines that need some extra seal... ( specilly if its blowing the dipstick out... fancy oil will just end in death...... thicker oil= 50,000 km more track thrashing before a rebuild)
fancy oil for your farken new built motor beer bitch!
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4113365
FATZ is correct
and i have seen him thrashing hell out of his machine
yeah he thrashes the hell out of it all right. right hand left hand, he's an animal. don't know if I'd call it a machine though, more like a little pistola....
usual suspect: for the defi's you don't need anything except the guage, and 1 controller. every guage comes with the sensor you need and the wiring you need.
this was the temp mounting. it's a bit average but was good enough for a while. I have a better set-up now, but not pics handy. the big shift light type thing is the oil pres warning light, set so it shines straight into my face! gauges are oil pres, oil temp, boost, fuel pres.
https://www.sau.com.au/forums/topic/234340-sump-baffles/#findComment-4113728
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
