  • Replies 170
Posted Images
Oh oh I'd like to meet all the SAU members with white Skylines at the same time so we could do a photoshoot of all the white Skylines lined up :P
that would be damn sweet tbh. we could get bunny, damo, cara, me and a bunch more
+1
-D
well, who have i met
cubes, sled, nightcrawler, heslo, PK (known him from the old CSA days), dohmar, flick + luke, ryanrb25 (known him from when he had his 25det 31), kye, cara, ben (GRIM), luke enr34, bezender, fishpaste (damn being neighbours and all) and a whole heap of others ive forgotten no doubt
most of yas probably have known me from my less than skyline-ish vehicles i appear in
Yeah...could have sworn I'd met ya before Matty. :P
I've met about 1/2 the people on here, but people I still would like to meet are Madaz (because he's the regular guy on here), ted180 (to check out those crazy rims) and the guy with Homer Simpson in his avatar, because that avatar rocks :P
Edited by Normsta
Once again a great idea for a thread Pete.
I'd like to meet most of you but who in particular??
SLED - Seems like a great bloke full of information
Cubes - Once again a wealth on knowledge
Ted - Get along on MSN and seems like a trippa
Ill speak to any of you tho :P
Edited by Ryanrb25
heh, I don't own a skyline but am very close to, just waiting for the right one/sorting through the internet.
But, I wanna meet Pete, because Kahli always talks about you, Ruby, because you're cool :P, Carl, Fishpaste, and Normsta because I LIVE NEAR YOU ALSO! Between Charlies and seacombe road.
hmmm im sooooo tired
met so many of you guys and ive even met some of you and had no idea who i was talkingto but you knew exactly who you were :D
um would like to meet Ted180 + few others
did i say i was tired i met my new exhaust today does that count Ben you don't have the loudest exhaust any more :P
Not sure if you have been following my thread in the mods section Joel, but Chris (REdgtst) and his alter-ego's miny_minor and max_iman_power have been banned for life :)
Muahahahahahahahaha, mess with mods and see where it gets you :D
i met u andrew :P wheres those pics i showed you from back in the day haha
i havent met many of the younger generation on here.. tho ireally havent been on the street in the last coupl years haha
maybe meet up with heslo just cause its weird having his car out the back n meeting his dad...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
