Hi all just thought I would make a post to say thanks to all the support on these forums over the years, the fruits of my labor are in the latest Fast Fours. Pretty Good article few mistakes but all in all its an honor to get on the cover of a mag.
Cheers all and thanks for the PM's of support really appreciate it.
https://www.sau.com.au/forums/topic/234962-fast-fours-cover-this-month/
nice betty in your sig, bit of a rod fan too.... not many of us around in sau :D
My boss was speaking with your dad and brother and i got the impression it was running a 30 bottom end or was that another engine?
Yeah the article didnt make a few things very clear.
This Engine and gearbox is rwd as the whole combo is going in a c110 skyline I am building at the moment, I built this motor as I had a lot of parts I wanted to test on it, for example I am mocking up a dry sump setup at the moment and it is cheaper to test it on this motor that already runs numbers, amd runs perfectly than to try it on a fresh engine that has not been run yet. This car has a 30 bottom end half completed for it, and it will be awd auto when that combo goes in. I hope that makes sense.
Also the rb25 block was choosen as it is easier to run the rwd sump (ie the tin one) than to cut a good 4wd sump and make it rwd as you would have to do for a rb26. Also this was a really pristine rb25, and it has an rb26 crank, rods, pistons, head so is more or less a 26 now.
Thanks for the comments guys cheers
I scanned in the cover but my scanner isnt big enough and its pretty bad quality.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
