  • Replies 153
My understanding is that the legislation hsa not changed, it always said 15 years old. the change is the practice of working 15 years on month of manufacture not year....if this is the case they have every right to make the change with no warning...
rumours have flown around Soulja, but it hasn't actually been confirmed until now.
Well its probably just enforcement of the rule they've decided to do, which yer, probably is fair if it is actually "15 years old" as in the car is 15 years old, not 14 years and 8 months, etc. As long as they don't change it further, which I am sure they will do when they can get it through..
I wonder what will happen to all those cars that have been bought already and placed into "free storage until they are eligible for import" as some importers have advertised?
There is a very good chance that they will be a source for thieves, especially if they are sitting around for over a year.
I think the reason they changed the 15yo rule to month built now is to give them extra time to intoduce a 20yo rule and abolish the 15yo rule. By introducing this new rule, that has given them an extra 6-8 months in which we cant bring in all the good cars that we want from japan. Then sometime next year they car introduce perhaps a 20yo rule and give it 6months to come in. This will allow the newer rule to come in before all the good 89 cars can get here.
This is what i think will happen. I hope it makes sense
What I can't figure out is who stands to benefit from the government stopping these cars coming in a few months early? It's just like the government being a total pain in the arse for absolutely no reason.
The 15 year rule is being enforced not changed as RAWS is a enforcement of some of the CPA rules to limit the amount of imported vehicles.
A lot of people went to the 15 year rule after they lost CPA so the rule makers are just moving through the hole process they have of importing sport cars not family cars.
People have been pushing the system to long so the rule makers are just standing up and saying enough is enough.
A 2003 Ferrari 360 or 1999 Supra TT is a sports car not a Hilux Surf and that is what the whole system is their for.
If you think about it... DOTARS themselves are the ones that benefit, as they don't have to deal with hundreds, if not thousands of 15 year import approvals in the first month of next year. Now they can deal with them ad-hoc as they come up over the year. That probably was purely been the reason why - to lessen the workload.
People maybe should get too carried away with it all..there may actually be no "conspiracy" behind it all. It could just be ensure they can adequately process all the cars coming through. Only way to really find out is to wait and see.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
