Hard pipe kits have been known to cause issues with compressor surge.
Same as changing stock BOV’s
In short – leave them both alone.
Seen plenty of cars make 400rwkw+ with stock piping. It's not required, nor should it be changed.
How do you guys get around the constant issue of blowing off hoses or the hoses splitting?
Seems to be a never ending process for me to constantly put hoses on with even the nut and bolt style band clamps.
And the other day I had the hose coming off the pipe on the on the right hand side running down past the air box towards the intercooler split!!
What does everyone use? Any brands better/worse?
they are not needed but I have found on track days the stock GTR stuff gets pretty soft (with heat). but plenty of people run 300kw with the stock pipes. but personally I much prefer hard pipes. I like the trust kit best. I use the trust suction kit and the trust intercooler pipe kit (need both). that replaces all the standard piping in the engine bay. they look nice. but for sure if you are on a budget it's money that is better spent elsewhere.
You can just user better clamps, that said I was using stock clamps for 20,000kms over 2 cars, and they were fine.
They were recently swapped however as it was suspected there might have been a minor boost leak.
Are you sure your engine mounts are in good order? Sounds like there is perhaps some more movement than normal going on?
Tried changing types of clamps, and even switched to the clamps I use at work (diesel fitter) which work on engines with 38psi running through them.
The engines mounts is actually something I completely overlooked. I'll have to have a bit of a look and see whats going on in that department.
Thanks for the imput Nismoid :)
or perhaps something else isn't affixed correctly and moving things around. have a good look as you really should not be having any major issues in that department
Yeah put it on a dyno if possible and have a look when it is loaded up at peak torque, should be able to see if there is much movement.
Yeah well its been on the dyno a few times in the last year and the shop that it was going to was not the best to say the least....
Anyway its going to Matty Spry down the gold coast hopefully in a couple of weeks so if i can't find it by then hopefully they might pick something up...
if by worth you mean spending 5+ hours to achieve nothing, then sure :)
you really only need to pull out the engine if your changing:
- mounts
- exhaust
- intake
- misc other stuff
all at once. otherwise, changing turbos is basically a 20bolt job, no need to pull out.
Operator10. Haven't done much yet. Finally got my car on the hoist at work. So will start on Monday night. Still haven't decided on turbos.
Engine wise check this thread I wrote it all down a while ago.
Ok was all set to have a big weekend and swap turbos and do a few other bits and pieces only to find out I can't get any -9s.
They only have -7s and -5s in stock.
Opinions on -7s? Responsive enough?
Otherwise I'm tempted to go small single eg. 3076 w/.82 rear
-7's are responsive but that depends on your definition of "responsive". On/off throttle they're great, they don't nose over at high rpm, and on an average boost setting they can give enough power to make a GTR feel like a whole new car. There's a few otherwise stock RB26's getting around the 310rwkw mark or so - area under the curve is great and you don't get caught in traffic wanting for more if that makes sense. It's also a good sized turbo setup that you can go have fun at the track or hills if that's your thing. There is probably a thread of 7's vs 9's somewhere - R31Nismoid would know of it
They have good get-up-and-go but if your idea of response is being able to pull like a freight train for 2000rpm in 3rd gear then I think you'll be disappointment (although if that's your idea of response, by a V8 :) )
Here's a -7 result;
Thanks for posting the dyno sheet N1GTR. I can see what you're saying regarding response as well. I had a chuckle at the "buy a V8" line as well. Very cheeky. Lol
With a built motor I will crank some boost into it and really see what the -7s can do.
Are the -7s bolt on in a 32 gtr?
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
