-7s being a tad more responsive again (over -9) would be an excellent choice if response is your #1 goal.
FYI, here's stock vs -7 boost response (very few data points.....its rough) same engine and probably same cam timing.
I thought N1 turbos were different to -7 turbos?? The legend on your graph says N1 whereas your text says -7. I thought -7 were a lot more responsive then N1.
  • 3 weeks later...
Hey guys, great thread, some useful information in it.
i am slowly working on my car to achieve just this set up 300awkw
at the moment, i have just installed
GT2860-7 x 2 turbos
Tomei expreme dump pipes
already has a front pipe, and a hks preist cat back with a high flow 3" Catco cat. (looking at changing exhuast to one with a bit louder/better flow) any suggestions?? rear cannon style.
i have a vipec ecu (which i need to get retuned but going to wait till after mods) MAFless
it has pump incar already, so that is a non issue.
suspension is all done.
i am at the stage of buying injectors, i have been looking at seimens injectors, can anybody give me some info on which type to run if they know about seimens injectors? part numbers etc, im looking at about the 600cc mark for injectors
Also never really though about cam gears, but might also look into those b4 retune.
Cheers
Daz
ive got very similar mods to urs Daz.
im running 600cc nismo injectors with a sard intake fuel pump with a direct 14v power supply.
im also running GReddy cam gears, i think they are great on an RB26. they gave me more flexability when it came time for tuning. ie i had a choice between getting them tuned for outright power or sacrifice abit of top end for more midrange power/torque :)
Whats your max injector duty? What power is it making and what boost is that at?
+1 on cam gears
Not sure on injector duty, il have to find that out
296kw @ 19psi - cam gears adjusted for midrange, feels so responsive And just screams out of corners like a mofo :) I'm happy with it 100%
Duty couldn't be too high with 600s, im running 700s and only seeing max of 65% @ 350-360rwkw. Has a minor rail pressure bump so move it to 70-75%
600cc @ 300rwkw, rough stab would be 55-65%?
Had a good read of this thread before I started my round of mods for 300kw. My mods so far are
2860-9
Nismo 600cc
New PFC
HKS cam gears
Greddy dump/front pipe extension
Kakimoto Regu exhaust
Splitfire coil packs
Hasn't been tuned yet because of coilpack and EBC issues. But I'm hopeful I'll get close to cracking the 300 mark but at this stage I just want it tuned and running
Time and time again I see ppl try to estimate duty cycle in relation to power output but it seems like we are leaving out the most inportant fator which is afr.
A car with 600cc making 300rwkw tuned at 11.0afr will show higher duty cycle than if it was tuned to 12.0afr and making the same 300rwkw.
Can any one explain why my boost curve is fluctuating, at a glance i'd guess some sort of fuzzy logic function however im pretty sure the blitz spec r are theoretically just an open loop controller with simple duty cycle adjustment. The car is running the standard 8psi actuators on dash 7s and the blitz boost controller set to 86. When i eventually fit bigger dumps (i have stock 32), bigger afm and retune on e85, i'd like to run more boost. Is it worth while upgrading to 14psi actuators?
Cheers
Pat
No different to estimating a dyno figure range or RPM turbos will come on.
There are always variables, however you can work out 'roughly' in most cases, hence its called an estimate...
Currently running -9s with 335kw, nismo 600cc injectors and fuel pump, with a max injector duty cycle of 86%
Just for reference
What air flow meters are using to get up to that figure? Are the standard still coping or have they been changed to Nismo or Z32?
My car is getting tuned in just under two weeks with -9s and 720cc injectors so i'm thinking the AFM's are going to be the next limiting factor.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
