  • 3 weeks later...
  • Replies 120
Posted Images
  • 4 months later...
Anyone seen or heard from Karl?
He seems to have dropped off the face of the earth
Sorry guys.. Mrs had a baby, working and trying to finish of my project car.. Back on board now.. I may not be here all the time, but i do check my emails for new messages. I can still make all the parts that i made before.
I have tried fitting my fitting Karl and they seem a bit slack in the cam covers. Wonderign if I should put some paint on the covers before trying to fit to give it that extra little tight fit that it may be needing? your thoughts?
Hi,
Sorry for yours to be a little slack. I make my parts based on the rocker covers that i have at work and this is the first instance i have heard that the fitting was a little loose as others seemed to be ok.
I do not mind replacing them if you like, as i like to keep everyone happy.
On the other hand you can just put some locktight on them or even a dab of silicon to make them tight or if you get the covers painted that will work too. Its not nesessary to make them tight (individual choice i guess). The main thing is that they do not leak, and as its not under extreme pressures it is unlikely to leak.
Please let me know and i will try to help you out.
Hope this helps.
Karl
Hi,
Hope this helps.
Karl
Hey no worries, I will give it some paint and probably use the loctite on it in any event. Work is top notch and me being in Trinidad for a replacement I think is too much of a hassle to give you anyway.
Cheers.
If anyone has the factory drivers side elbow let me know i will buy it off you.
Sorry can't help.
Can't wait for summer to come and finally get the car down calder when it opens up again.
Thanks for your support. I have some seconds of parts that i am keen on getting rid off (rocker cover fittings RB25) Make offers. The only thing wrong with them is that they are little rough on the treaded section (nothing serious just a few chadder marks on them) and when fitted you will not know as the visual section is normal. They WILL tighten as per normal. I think i have only to suit rb25 though and there is about 4 sets. All offers considered, but you pay for postage if needed. These are the parts that karl rejects although functionaly perfect.
Thanks
Karl
  • 4 weeks later...
im after a set of rb26 ones
pm me details plz
or i might be able to pick up as im s/e melb aswell
x2 for the RB26. I'll cover shipping to canada for the right price. Are the fittings compatible with earl's or goodridge connectors?
Edited by NismoSTune
Hi. I don't see why they will not work on the earl or goodridge style. The dash style (speedflow) are imperial sizing (u.s) so they should work. I think that its a standard they all work to for fitment
If you need 2 pairs i will throw in regular air mail to canada.
Let me know,.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
