  • Replies 120
Posted Images
hey mate, any luck finding those fittins? :ermm:
happy to pay postage plus a little more for your trouble. PM me if you found some
If not, someone help me out :P
Sorry, i think i threw them out.
Good luck.
ah well if you do any fittings for someone with an R34 RB25DET NEO, you know where to find me :touch:
No problem. I will see what i can do. I have a few friends that own workshops so maybe they will have some laying around.
If someone is willing to give me their RB25 NEO rocker cover fittings, I may be willing to pay for some of 'tufrx3's' fittings for your car :thumbsup:
If someone helps him out and want a pair of fittings i will give them for $35 including postage... But you need to help out 89cal for this.
Hope this helps...
Hey mate at the back of the rb26 rocker cover the twin head fitting on that is there any push in fitting you can do that will take a -12 push lock fitting?.
I have the gates push lock hose and you just can t get the bastard onto the standard fitting to use the standard clamps.Even after i hacksawed off the bump in it the hose the way its made will not strench due to the braid inside it.
IF you have made something up for other guys please feel free to shoot me a tell id like to replace all 6 at the back of the motor to replace the hose's with new gates stuff and to run the hose for my catch can that has aero push lock fittings on it ready to go.
Hey mate
Got your PM but can't reply on my iPhone for some reason. Thanks for that but. Anyone who wants some fittings for there RB25 NEO let us know and we can do you a deal lol
Are these fittings the same as a from an RB25DET R33 normal motor?
If so, I have some I am going to remove shortly.
PM me to let me know (I don't check this section much)
The neo engines have a dual fitting with the 2 outlets at 90 degrees to each other along the horizontal
The R33 25's have the dual fitting that points upwards and to the front. This is why I want to swap, see my sig photo, it looks pretty crap pointing up and having to run a pipe at a big 180 to go back down to my intake pipe lol
  • 4 weeks later...
  • 3 months later...
  • 2 months later...
  • 2 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
