I have been hunting UK car forums and classified for months now looking for what it is a basic fun car that will give me low key transport whilst in UK and double up as a track car. I keep coming back to E36 M3 BMWs :mellow:
They are common, cheap and plenty with decent mods....and i figure practical enough. This is a typical example of what you can get
http://search.autotrader.co.uk/es-uk/www/c...mp;max_mileage=
Anyone have any idea how decent the things are to be punted at speed
https://www.sau.com.au/forums/topic/237623-euro-track-car/
  • Replies 80
Yeh has to be rwd and reliable for the flogging its going to cop. I buy it, my mate uses it and garages it. When me or any other friends are in town its going to be our Snetterton, Brands Hatch, Oulton Park, Spa, Magny Cours etc car. So std and reliable and still fun to punt is what is required. There is a chance that it may even make it all the way to the place in Germany for some communal love :P
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157481
I was considering an E36 M3 as a daily before I bought the clubbie, but I couldn't afford one with low k's on it, and it wasn;t very practical. I love them, but I know a few people think they're quite front heavy...
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157557
E36 is hard to go past. Bolt on front brake upgrade, and if she's a fit one, it'll be all rosy :P
I've driven them, and reckon they're a good thing considering the daily livability.
To allay your "leg out of bed" fears... maybe some kind of aftermarket rev limiter should be on the cards? What do you reckon Bam Bam limiter guy?
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157604
Good choice and hard to go by for coin like that :P
Great handling car and, in factory form, fairly neutral from a balance point of view (easy to control the oversteer). Bad points include the fact that if they are abused like the way you treat the gtst :) they will break things and parts stamped with the BMW logo aren't cheap :P
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157611
Come on mate give SMAUG some credit - he's done a LOT more than just that.
He's blown the engine, gearbox (x2), clutch plates, front diff, rear diff, a turbo, 2 rear shocks and a tyre on the track (not all at once thank god :P )
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157621
if you could blow 2 gearboxs at once then i would give you gtr drivers so much credit.
ooo what about this M5 - and you can comfortable put the irish birds in the back :)
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157684
Old Porkas would be the sort of thing i bring home...not buy as a track car to thrash as they are not that quick, hopeless in the suspension dept and expensive for parts. E36 is good in that i can throw some meaty 16" semis in the boot for hammering around on,
The budget is about 6k max. Anymore and i risk doing too much damage to a decent enough car. I am buying a Cossie while i am there to brign back as a private import, and really if i am going to spend more then 6k then i am better of jsut repairing the stuff that breaks on teh Cossie at the track :cool:
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4158808
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
