I have been hunting UK car forums and classified for months now looking for what it is a basic fun car that will give me low key transport whilst in UK and double up as a track car. I keep coming back to E36 M3 BMWs :mellow:
They are common, cheap and plenty with decent mods....and i figure practical enough. This is a typical example of what you can get
http://search.autotrader.co.uk/es-uk/www/c...mp;max_mileage=
Anyone have any idea how decent the things are to be punted at speed
https://www.sau.com.au/forums/topic/237623-euro-track-car/
  • Replies 80
Yeh has to be rwd and reliable for the flogging its going to cop. I buy it, my mate uses it and garages it. When me or any other friends are in town its going to be our Snetterton, Brands Hatch, Oulton Park, Spa, Magny Cours etc car. So std and reliable and still fun to punt is what is required. There is a chance that it may even make it all the way to the place in Germany for some communal love :P
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157481
I was considering an E36 M3 as a daily before I bought the clubbie, but I couldn't afford one with low k's on it, and it wasn;t very practical. I love them, but I know a few people think they're quite front heavy...
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157557
E36 is hard to go past. Bolt on front brake upgrade, and if she's a fit one, it'll be all rosy :P
I've driven them, and reckon they're a good thing considering the daily livability.
To allay your "leg out of bed" fears... maybe some kind of aftermarket rev limiter should be on the cards? What do you reckon Bam Bam limiter guy?
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157604
Good choice and hard to go by for coin like that :P
Great handling car and, in factory form, fairly neutral from a balance point of view (easy to control the oversteer). Bad points include the fact that if they are abused like the way you treat the gtst :) they will break things and parts stamped with the BMW logo aren't cheap :P
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157611
Come on mate give SMAUG some credit - he's done a LOT more than just that.
He's blown the engine, gearbox (x2), clutch plates, front diff, rear diff, a turbo, 2 rear shocks and a tyre on the track (not all at once thank god :P )
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157621
if you could blow 2 gearboxs at once then i would give you gtr drivers so much credit.
ooo what about this M5 - and you can comfortable put the irish birds in the back :)
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4157684
Old Porkas would be the sort of thing i bring home...not buy as a track car to thrash as they are not that quick, hopeless in the suspension dept and expensive for parts. E36 is good in that i can throw some meaty 16" semis in the boot for hammering around on,
The budget is about 6k max. Anymore and i risk doing too much damage to a decent enough car. I am buying a Cossie while i am there to brign back as a private import, and really if i am going to spend more then 6k then i am better of jsut repairing the stuff that breaks on teh Cossie at the track :cool:
https://www.sau.com.au/forums/topic/237623-euro-track-car/#findComment-4158808
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
