Hey all,
I was going to buy a Bee*r rev limiter for my 33 GTR just to keep it to 7000 revs or less just to be safe.
But someone said the power fc i have comes with an in built rev limiter that you can set. Is this true?
I tried the manual but dont speak japanese! lol
Does anyone have a step bystep to changing it?
And is it safe to realy on the power fc rev limiter?
cheers
https://www.sau.com.au/forums/topic/238257-power-fc/
Yep, i have mine set to 6900 rpm. I believe its in the setting menu and then rev/idle or something. All you do is keep pressing up or down on how many revs you want it to limit to, very easy.
Some people set it to 3000 rpm when they give they're cars to a mechanic for a service so they don't go thrash it.
https://www.sau.com.au/forums/topic/238257-power-fc/#findComment-4165377
i have a similar question to finchies.
is it true that the pfc limiter cuts fuel, and not ignition????
this would explain the no bang bang and just dying like hitting a wall
Edited by r33cruiser
https://www.sau.com.au/forums/topic/238257-power-fc/#findComment-4165961
pfc cuts fuel..... im not 100% sure but im pretty sure its a fuel cut.... even tho mine went bang bang nicely aswell. but in saying that my mates stock 33 with a lil bit of boost increase does almost the same just not as loudly. im pretty sure if the pfc cuts igniton and not fuel there would be many ppl complaining of blocked catalytic converters due to the extra fuel....
https://www.sau.com.au/forums/topic/238257-power-fc/#findComment-4166281
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
