mythbusters ahoy!
standard powerfc
FUEL CUT on REV LIMIT (which is set via hand controller) (or datalogit) - there is no other way to adjust it
powerfc pro
SPARK CUT on REV LIMIT (which is set via hand controller) (or datalogit) - there is no other way to adjust it
+ also with launch control
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4166359
ok well i did it, i set it to 6950 last night.
two things.
1. even tho it was set at 6950 it still spiked out to 7215rpm when i hit the rev limit hard. is that normal?
and
2. Does it hurt the engine or anything bouncing it off the limiter?
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167152
do you have to turn car off and back on again to get the settings to stay in?
i've not fiddled with a power fc for a while
tho maybe not true, as i remember sitting at lights and adjusting the launch control (gti-r) and that changed right away. now there was a few funny looks from other motorists, Bang bang bang bang!
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167209
No
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167443
if the engine couldn't rev happily to 8000rpm they wouldn't have put the factory rev limiter there.
So what I said about the factory limiter being at 8000RPM is correct?
Why the hell lower it to 6950 then!!! It's CRAZY TALK!
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168053
ive been told that 8000 is way to high and should reali be kept around 7000revs... so daily i wouldnt need any more then that.
Just being safe..
On a daily car, it is fine.
On the race track, stick a bit lower down. (This is why the ex bathurst GTR ran a 7000RPM limiter on race day, but during prac/qual ran 8000RPM...)
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168121
also dude, if its your daily, how many times in a day are you going to be bouncing off you rev limiter?? im sure you will give it a squirt here and there, and if you do, having you rev limit at 7500rpm is fine, even 8000rpm! but just dont sit there and bounce, obviously then you asking for trouble. with these motors, in first and second you still pull when hitting 6500 - 7500 or so, so if your changing gears early, then you wont be inside your torque range in the next gears.. and so on...
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168137
so your saying hitting 7000rpm on a daily basis is fine?
Is this a trick question or a very silly one?
Not sure... so im gonna reply with one of my own
You sit on the limiter daily driving?
No.
So of course its fine for a daily driver.
Bouncing of a 7k limiter would be FAR WORSE than reving the car to 7500rpm and changing naturally.
You often come here with some misinformation, so wherever you keep getting it from, you need to stop going there or talking to that person.
7500rpm would be FINE. However, are you making power there on the stock turbos? Probably not that much so changing from 7k-7.5k would be the spot
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168229
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
