14.X
Last time I went up to test and tune every skyline i saw there ran a 14.X it was pretty sad cause a number of them had more than exhaust and cooler
I couldn't run cause i forgot to wear long pants!!!!! I wanted to see how i would go before the 3L went in
In all seriousness I actually ran 14.1 with stock boost, pod filter and full exhaust. I'd expect to run in the mid/high 13s with a front mount and a touch more boost.
And then the turbo blew its ass into mexico and you had to tow it home didnt ya? :P good 500km? LOL
And then the turbo blew its ass into mexico and you had to tow it home didnt ya? :( good 500km? LOL
No that was a completely different event, I didn't even manage to get a run that day and it was the only time I had >200kw at the wheels with stock turbo.
My R34 GTT with a cat back and 11psi ran 14.0@97mph. MPH was down on that run but sadly it always goes down with a good launch.
It will do 14s.
105mph with a cooler zorst and boost!? Standard computer etc? Thats alot of top end for those mods 10WRB gotta be happy with that
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
