I have decided to post the results in the thread...
The previous test back in Feb 07 my results were
THC 0.39 NOX 1.01 CO 2.6 CO2 287.3
That was a pass. the requirements for my model car is
THC 0.93 NOX 1.93 CO 9.3 (CO2 not required)
Yesterday the results were....
THC 0.62 NOX 0.69 CO 1.1 CO2 312.7
If it was not for the fuel spike when going up the hill at about 170 seconds in then the THC would have been down to around 0.25 I would say... If i had of used the same CAT as i used last time.. things would be very different.
HOLY CRAP!
I been reading on the net a bit about IM240, and i came across this.. In California..
"Help for poor folks. If a vehicle fails a Smog Check inspection, but the owner cannot afford to make the repairs, the owner may be granted a "repair cost waiver" if the owner first pays for at least $450 in emissions-related repairs at a licensed repair station. This waiver is good for two years, and only one waiver will be issued while the motorist owns the vehicle."
AND...
"There is also an "economic hardship extension" for qualified low-income motorists. Like the Repair Cost Waiver, the extension is valid for two years and may be obtained only once during a motorist's ownership of a vehicle. However, to obtain an extension, motorists must spend $250 on emissions-related repairs at a licensed Smog Check station, or have an estimate from a licensed Smog Check station showing that a single repair would cost more than $250. Motorists must also verify their household income, which must be at or below 175% of the federal poverty level (about $29,000 a year for a family of four)."
http://www.aa1car.com/library/im240.htm
WOW!.. I wonder how many people here could have applied for the "repair cost waiver" LOL
That's not a joke. Ethanol is alcohol. It is the basis of commercially produced spirits. Apparently people who make their own ethanol have to put some (2%) petrol in it 'so that no one will drink it. In American Drag racing there is a class called "Top Alcohol" which is for methanol powered cars (methanol is chemically very similar to ethanol but methanol is naturally poisonous so undrinkable).
Aus has a top alcohol division as well... bloody kiwis :wave:
They add Methanol to ethanol to make it undrinkable, not petrol. This is what you would know as Methylated Sprits or Denatured Alcohol. It used to be about 10% Methanol that was added to Ethanol.
Top Alcohol as a drag racing class is bloody awesome and is run in many countries including Australia.
Yeah Father Dirt has a early chrissy pressy for me when i go back up to newcastle on friday :(
hmmmm.. going to be interesting trying to tune this ecu :) lucky i have the master AC from Turbotechnics to help me on saturday
Guess who's got themselves a new more advanced ECU...flat shift, launch control, anti-lag, full logging etc...?
And it will now allow the car to be driven while its raining!
Ahh AC the master AT
yeah looks like it mate. I cannot move forward with the PFC anymore.. I have learnt all i need to know about PFC's.. time to move onto bigger and better things.
what the funk?!
You're dropping the PFC?!
I CARN BELEEF!
what the funk?!
I CARN BELEEF!
Yes and he is removing The KLF from his CD collection too.
The 90's were very good but its time to move on.
GTST i always thought the LX Torana style drop tank was more his look.
Edited by DiRTgarage
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
