Now I know I shouldn't take everything I read on NS.com as gospel :D
.....but I lifted this comment from a recent thread post
"I spoke with a guy at the Mawson Lakes servo, he said the letter the government sent them stated that the government has now classed E85 as a race fuel and dont want young people running their cars on it and getting more power from it, so they banned it from retail sales across Australia.
He told me if I go to the servo, he will happily show me the letter he was sent."
What does this all mean :huh: ........I know go back to my opening comment. :D
Anyone shed any light on this.....
PS I think Mawson Lakes is in SA......but I was never good at Geography.
Edited by juggernaut1
what a load of bullshit. its because the pump's don't meet the standards and only the United service stations have invested the 40 grand per servo for the upgrades.
why would you listen to that bullshit?
ok, i spoke to fuel standards aust today, and the dept of sustainable resources or some shit....
the dealio is...
e85 is legal to sell still, but there is only 1 model of bowser that is legal to use. these are the ones that united have.
it went on sale temporarily in other types of bowsers, but they have now been shut down as the companies producing them will not give assurance on the lines being capable of holding e85
united have 1 servo in melb, 1 in syd, and they are not giving up any info on whether they will be adding more
quoting myself here.....
The above quote is from me on Nissansilvia.
I had been running E85 for about 4 months until they stopped stocking it. This is what I was told by one of the guys that work at this servo. I asked about the pump issue and I had heard of the problem being OHS related, he said this was not thet case.
Cheers
Anyway, All Im 100% sure is that I am now missing some power without it.
NOT HAPPY
united on victoria rd in rozelle still have it at the pump
and united hoppers crossing vic....
they have spent the money on the approved pumps, so they will NOT be stopping :(
as a side note guys. the dept of bio fuels have contacted me and want information on what we are doing so they can lobby government :D
i'm gonna quote myself again, but from my e85 thread, as some of you might not be reading it :D
i was on the phone to chris from centreline suspension yesterday and he was telling me how he killed his rotor on the dyno with e85
the car is an 800kg stripped out rx3 (by memory) making a naturally aspirated 330rwkw and is a full drag setup, im talking fuel cell, surge tank etc...
the problem occured when the e85 corroded the rubber fittings in the fuel system and the car leaned out @ 11ty billion revs
we talked about it for a while and worked out that the types of hoses he was using were NOT silicon based.... it seems not to be a problem in skyline fuel systems, but when you go aftermarket, just make sure you run silicon methanol rated equipment i spose....
discuss...
As far as hose choices go Teflon should be the best (although some further investigation into long term-use and thorough testing should be done before i make any statements), and reduces fuel vapour seekage, to me it sounds like a viable choice as it gives you the flexibility of a variety of fuels and eliminating one of the worst factors when it comes to aftermarket hoses.
Can you please clarify if it was the fittings or the hoses?
I think I remember reading somewhere (was a while ago) that there were different requirements for storing E85 in quantity , meaning the underground servo tanks/reservoirs .
It may have had something to do with preventing water or water vapour contaminating the high ethanol content fuel .
So its quite possible that the cost of setting up for E85 goes beyond the pump and hose .
A .
A .
Yes.. it costs united 40 grand to setup the tank / pump / servo for E85. no wonder they are in no hurry to upgrade more servo's
Just kinda to recap a bit...
the only downsides so far are...
- availability
- a few more fuel filter changes?
- cleaning the valves a bit more regularly? say every 50,000km or so? i guess i'm using the term "regularly" relatively...
that's it?
i recently was talking to a guy who runs E85 on a rotor, stupid power, stupid boost, insane levels or everything :D He was saying that you can't lean on the timing as much as everyone thinks, and it's not as safe as everyone thinks.
I mentioned there were people who have gained ~50rwkw from just changing to E85, and he said yes but dangerous as most likely done all with timing. I got the impression though that this guy knew some things, but perhaps not everything, even though the impression was he knew pretty much all there is to know about E85, etc. I was dubious given the results some people have had here on SAU with E85...
Now, the percentage of knowledge i have compared to you guys is about 1%, but i thought one of the many benefits of this fuel is to realise more power by advancing the timing, but in safe manner?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
