is this motor run on pulp too? if so what's it make on that?
i know of a few stock rb25's making 350ish on pulp that are still holding together...
i'd like to shoot for higher figures, but in reality, anywhere i go from here just means lag...
and softer, more expsensive tyres LOL.
my car made 350rwkws (22.5psi) on BP98. 318rwkw on only 17.6psi. Id certainly give 400kw a go with e85, only if it becomes available in my state at the pump tho.
has anyone used e85 on a NA engine without bumping up the compression? how would it work? any ideas?
DO IT... i love tuning turbo hondas for exactly the same reason, super responsive revvy little fkrs.
SOMETHING NO ONE HAS MENTIONED IS OILS AND COMPATIBILITY WITH E85
Consider using oils that are methanol safe. Ive been speaking to a few engine builders and machinist involved in E85 powered race cars (hint) and wear is UP TO 20% FASTER than experienced on "normal " fuels.
So what 'street' oil is suitable for E85?
I've been running E85 is one of my cars for almost 3 years, that's around 80,000 k's and it uses my standard oil for RB's, Castrol Edge 0W60. The usual oil change interval is 8,000 k's and, not that looks is everything, but it comes out of the engine looking much cleaner than it did with Pump98 in the same engine. It also doesn't smell of stale/burnt pertrol.
For the drag cars using methanol I used to change the straight Castrol W50 (now Edge 25W50) every race meeting and I notice the sprint cars guys do the same.
In the race car using E85 I will be sending the most recent drain of Castrol Edge 0W60 to Technical for analysis. Asside from the usual engine condition diagnosis it wil give me some idea of how often to change the oil in it.
Cheers
Gary
20 % more power = 20% more wear ?
I guess it depends what "normal" fuel they were on before and the power levels.
No they are getting the same power as they were running sunoco before. I cant post up the details as they wish to stay anonymous. One of the V8 supercar teams we went and did a corporate day with also advised / warned me they have also revised thier O/H strategies for E85 too.
Edited by URAS
Interesting. I would have thought E85 to make at least a little more power then the Sunoco.
Have they given you any idea on what area's are increasing in wear ? piston rings ? bearings ? etc ?
i consider 10-20rwkw close enough to same @ thier power level.
It tends to be a boutique oil issue, and ive since heard that 300v and E85 issues may be based on one workshops experience (feedback to link) so i might look into the 300v thing abit more.
Just going to throw this out there...
With my motor (SR20DET) I run a 30% toluene mix as the motor was making enough power to trap 131mph in a 1200kg car, and im making 80rwhp more now. If i replaced the toluene with ethanol does anyone have any educated guesses what would happen to:
1. knock resistance
2. power
3. fuel consumption on full load - i.e. would it use more fuel with the ethanol than it does with the toluene on full load
It seems both ethanol and methyl benzine are great knock resisters when added, but now with toluene at around $2L im wondering if it would be smarter making a shift to adding ethanol instead.
Cheers,
Ahmed
With the current turbo combo it has been tuned to E85 only. TBH cant see him even considering 98 at this stage with E85 available at the pump again in SA.
I hear what you are saying about more power=more lag and for that reason i'm keeping my HKS3037 on my car also at 2.5 litres.
A 3 litre would be nice one day tho with a XR6 turbo 1.06 rear and .7 front. Would make some decent power on E85 i would think (pipe dream at the moment). Or i could tune the BF to E85 and have the 2 tunes on my XCal (pump and E85)could be a cheaper option but a broken daily doesnt sit too well with me.
Edited by RB25DETS2
you will need to re-tune the car. where are you located? i can suggest a tuner with E85 experience
1. knock resistance
2. power
Cheers,
Ahmed
Do it Ahmed :)
But for the your power level you'll need another fuel pump and bigger injectors.
To give you some idea I get 200km's to a tank of hard driving. 1600cc injectors, 2 x 044's and 503hp @ wheels.
On pump fuel I used to get around 330km's, and about 300km's on my toluene tune (1000cc injectors)
But, cooler water temps, EGT's....car runs beautiful. Can't beat it!!
Ive been using 300V in my engine and is dropped every 2-3k. And before every track day.
Comes out a little milky due to the condensation caused on startup/warm up.
Just got back from J-land with some nice goodies to throw on the car :)
A few gear knobs, Top Secret, Nismo. Some shifter extenders, never seen them before so ill give them a go.
Tomei Trax 2 way LSD
GTR Rocker covers.
HKS Bellmouth, picked up from Garage Saurus, my favorite, looks horn in the engine bay.
There was a titanium one at WELD but they wouldnt sell it, and we threw down alot of money too!
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
