from what ive seen E85 is on par with racefuel up to 30psi...its beyond this that the racefuel takes the lead in the power stakes.
What racefuel? I've tuned some big hp, 25psi plus xr6t on vp109 and E85 and I can tell you that you can definately find the detonation threshold on VP109 where e85 you could just keep putting timing in with no knock what so ever.
Unless you're speaking of a particular brand and even then, a batch, that's not always going to be an accurate statement.
i am speaking of a particular brand...thats why i said 'correct'
Roo16 of course.
  • 3 weeks later...
thanks dude..
just asking cas i wanna get it tuned with a 20L in it. reason why 20L is because Jerry Cans are in 20L and it would be handy to tune a mix of this in.
What if I just putt it around to my Tuner?
It would only be driven for 20-30mins. try to stay off boost as much as i can?
Cheers guys
on my pulp tune with ethanol we couldn't even get it to run enough for a single pass...
just get a jerry, fill it, og to the tuners and THEN empty out your 98 and fill with 85
I'm hopefully getting my mine tuned in the next 10 days or so with E85.
Now i have an ECUtalk thingy that lets me add fuel and timing across the whole map up to 20%. Will i be able to safely fill up, add some fuel and get to the tuners (prob 20km away).
Thanks in advance.
James
its really not that hard to fill up at the tuners...
take off return line and attach some fuel hose, turn car on and wait for jerry to fill... when tank is empty fill from e85 jerry can
it takes like 5 mins
Yea it would run i guess. But i and others would not recomend it as your pretty much flying blind with no idea how your afrs are
20% is just a guess, you could be way off at certain load points - and its not like your gonna be coasting the car to the tuners, your still gonna have to put the car under load here n there
Wonderful news:
Caltex will support the introduction of the new E85 Commodore by installing E85 pumps in 30 metropolitan and regional service stations later this year and increasing that figure to 100 within 12 months.
http://theage.drive.com.au/motor-news/the-...00324-qv7k.html
Quote: And the car maker has committed to launching a Commodore that is capable of running on 85 per cent ethanol by the end of the year.
Holden have been making 100% ethanol cars for years and shipping them abroad haven't they?
Also, I don't like the government getting involved in anything or it will be bound to fail. :blink:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
