Caltex Moorebank (Newbridge Rd) Sydney
Last night
Pump is up n running :P
Asked the Attendant if its an 85% blend or 70%
he reckons its 85% since the weather is getting warmer, and E70 is only sold in Winter when its real cold.
anyway usually when i run the stuff from United its always E85, it smells like ethanol and cold start usually stutters for a few seconds before it idles smoothly
this caltex stuff that i filled up with last night starts up 1st go perfectly so im inclined to believe that it isnt exactly E85, but closer to E70 than anything just judging from the cold start difference, and also it smells more like Unleaded than the United stuff.
Who knows
but runs the same, doesnt seem like its running richer, nor does it Knock AFAIK
Edited by aym23q
cool. I live just 2 mins drive from the united at rozelle but more servos around the place is a good thing. have 1,000cc injectors in the new GTR so am very seriously considering trying it out. :D
I should go past Kambah and check it out there....
But how bloody much would a full tune set me back in dyno time! fark.
It shouldn't take more than two hours to get tuned properly. Im lucky, I have a local dyno I can get on for $50 an hour now, BYO tuner. :worship:
How much were you quoted and hour?
So over the space of a few days i read this whole thread a while ago. and remember a topic on oils to use with e85.
what oils do you guys use with the e85?
Sougi 6000, discontinued unfortunately.
I used to use 300v without any issues but I would suggest you use the stock water thermostat if its a daily, as the oil needs to reach 80 degrees, to boil all the ethanol dumped into the sump at startup. (Otherwise the oil will go all milky, mine did with the low temp thermostat)
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
