my goodness, you're running semi synth oil on engines like those?
you'll find most guys on here will be running AT LEAST a fully synthetic oil (like 99% of people) of Group IV or higher. A lot of oils unfortunately market themselves as synthetic when in fact they aren't.
Motul 300V Chrono is a very popular one. Redline for those that want a full Group V oil, but $$
AMSoil, Royal Purple, German Castrol, Mobil 1 - some other decent full synths.
5w30 would probably be the go, especially since you're in NZ, you'll be wanting that cold protection more than us. Unless you the engines see's a lot of track time. I'd be looking at a 0w30/40, or say 5w30 for street duties
the car does mostly drift but a bit of other motorsport stuff as well so a bit of thinking to do
this is the oil we were using
http://www.lubadmin.com/upload/produit/Fic...ang_29/5285.pdf
cheers for your suggestion. we will have to look for a suitable replacement
In Case it hasn't already been mentioned. ANDRA have BANNED E85 as a competition fuel.
Pretty crazy considering they allow 100% ethanol.
I am chasing up the ANDRA fuel guy about it but having no luck.
saw that one coming...
For the SA boys, the Liberty on tapleys hill rd seaton has E85 at the pump, 99.9c :happy:
Thanks for the heads-up Adrian. I've been buying mine from Peter at Scotchers. Any idea what blend the Liberty is 91/E?
Rumour has it that Mobil are starting to sell E85 at their petrol stations.
Unclear if its Australia wide just yet, but there is atleast one in sydney that has started selling it and another (near me) that has just had new tanks put in :)
Taken from Holden's wesite - notice the second sentence. Hopefully widely distributed commercially available E85 is only a matter of time.
Although E85* is not yet widely available in Australia, at Holden, we're working hard to make E85* the everyday fuel for Australian drivers.
In 2010 we'll be launching an E85* flex-fuel vehicle. This vehicle will run on any ethanol blended fuel from E10 all the way to E85*. Plus it'll also be able to run on normal petrol should the need arise.
sorry mate, no idea, ill ask next time I go there, i'd say it be 91 tho, i'm happy, goes good.
not driving it much so wont be keeping too much on hand, 40 litre's at most, the last 44 I got took too long to empty, I recon it went off toward the end, power seemed down and was hard to start!
Looking at the results of this thread has got me pretty excited and pretty bummed out at the same time.
Bummed out because I do not have access to any ethanol in this country (if you have kept up with my current adventure you would understand) .. Excited because I can see all the testing and time I have invested in e85 last year is paying off, there seems to be a big e85 trend going on since I stuck my neck out and tested this stuff in my car, Just search for E85 on google.com.au and you will see how many other forums are linked to us here at SAU.
Looking at the results from Trent @ Status Tuning - URAS has backed up everything that I have found on my initial testing of the fuel. I found a 40 - 50 rwkw increase with my setup but I was using a bigger turbo charger so you cannot compare them with this setup 100% but it does show that when you have a experienced tuner working with this fuel you can see major gains with no other modifcations as long as the fuel system is up to the task then you will have gains all across the board.
It is good to see that you guys are still working on this boost juice, without the support of tuners like Trent and enthusiasts like Joe Joe, Nytsky and Now the all famous Dirtgarage (AKA Twoogle and Mark Jacobson @ Godzilla and a few others like Yavus @ Unigroup Engineering and even JEM) it really puts SAU first in line in Australia for for this remarkable race gas in a pump for only 0.99c a litre.
So yeah, I am sure I do not only speak for myself when this warm fuzzy feeling of E85 love gets its share of internet hits... Its because of tuners and and enthusiasts like us who make it happen.
Keep up the good work! Someone needs to try and and push a complete stock RB25DET to as much power as possible with this fuel... are you up for the mission Trent? :D Can anyone say 400rwkw ?
Theres a user on here pushing 380rwkw (mainline dyno)on a stock engine which he tunes (the car has been running e85 for well over a year now).
Theres no doubt theres 400 in it.
The top end of this car is really something else.....The fuel is very forgiving its awsome stuff.
Edited by RB25DETS2
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
