Hi!
I'm budgeting 11-sec GT-R build and wanted to ask for some pointers, suggestions.
Actually it will be AWD A31. I guess the weight will be compareable to R32-R33 GT-R.
All the AWD gear will come from R32 GT-R.
Now I need to budget the engine build to run 11-sec. Car must be reliable, must survive more than one 11-second launch.
Right now I'm thinking:
New garrett turbos (-5/-7)
R33 crank
Freshen up the engine
New oil pump (Tomei or Jun? They cost a leg though)
New piston rings
New bearings
Water pump
Oil restrictors
Tomei Oil pan baffle kit
Trust over size oil pump extension
Oil cooler (for increased oil capacity)
600cc injectors
Tomei/Nismo fuel pump
NISMO AFMS
GTR PFC
or
Dejetro PFC and no AFMs
Clutch:
ORC/HKS twinplate
Nismo strengthened spigot bush
Rear:
2 way lsd/locker
Car will probably run without interior.
What you guys think, can this setup pull 11-seconds ? Or Early 12s ?
Thanks!
You could probably run high 10's with that setup..
Check out this thread
http://www.skylinesaustralia.com/forums/Ra...ek-t226580.html
depends what boost you want to run but you could get 350awkw and do high 10s without damaging the engine.. how long it will last depends on lots of factors tho..
Edited by Tomei_32
heard of high 11's with a "tweaked" stock GTR (cam gears, boost, fuel reg). But then again... "half of what you read" etc etc...
Less is more.
:kiss:
Hi!
R33 crank
New piston rings
New bearings
Water pump
Oil restrictors
600cc injectors
NISMO AFMS
GTR PFC
or
Clutch:
ORC/HKS twinplate
Rear:
2 way lsd/locker
Thanks!
i ran pretty much the same set-up except for HKS 2530's, Z32's, single plate clutch with 720cc injectors in a 1464kg car to run 10.36 @ 134 MPH
don' worry about 11's...make the goal 10's
the car was ultra reliable until rear turbo failed due to an oil feed blockage.
Edited by DiRTgarage
run 100hp gas on the standard set-up on 1 bar. will cost you about $1500 to set it up properly + a fuel pump, computer and good single plate clutch. thats it. a taxi can run a 11sec pass these days. the combo you are talking about will cost you 20k. and will be good for 10s.
reliability?
1 Its an RB26 >_< ...start from the crank...many drag cars use billet counter-balanced cranks.Don't bother
with a R33 GTR stock crank...their normally cracked and partly bent from the factory.
Balance is the key to creating a reliable engine.ie..have your rods balanced and your pistons weighed etc etc etc..
2 Get a better than average tune....don't be scared to spend money here...ask him or her what they prefer
DJETRO of Standard PFC.You though have not mentioned a good boost controller.
All the rest of your mods are great..they seem to be supporting mods..I guess you will be using stock pistons, rods, cams valve springs etc etc etc. I suspect your head gasket may need to be metal and u may continplate using a
set of new head bolts.
All of a sudden it sounds like your going to spend well over $25K.
Reliability is also never certain.
Your gearbox will need a little attention too....syncros fail here and I still need to discuss with my Guru if there
are any titanium or alternative ones on the market I can use on my gear-box build.
Os Giken and others though have some after market options for this...but very expensive,
Your clutch being a GTR32 type is a lot smaller than the GTR33/34 type. Giving it many hard launches will
give you heart ache after heart ache.Triple plate anyone?....not sure how to address this...you may need to speak to some one who has used a gtr32 as a drag car to see what he/she suggests can work on the street as well.
You did not say if this car was going to be used on the street as well.
There is also no mention on how many times you intend to go to the drags and achieve these constant 11or 10 second runs.
Hope I have been of some help.
11's on stock sized turbos isn't hard. If you only want to 'dip' into 11's then sticking with something of similar size but, steel wheeled would work fine for some frequent use.
Get some 10sec action by bolting a nitrous kit on to the stock turbos if you like. go a 150 to 200hp shot in a single fogger.
If you decide to go NOS brand go buy some of the bigger solenoids to replace the dinky ones they supply in the cheaper kits. Saves you mucking around with rebuild kits later if you use it a fair bit.
freshen up the stock motor with a good oil pump, cryo the crank and hpc coat the stock pistons.... then get it ballanced! Run a good exh and any steel wheel turbos. 044 intank pump, clean stock inj and a nismo FPR. Get your stock computer re-tuned for the new set up or a PFC. Good single plate clutch, good lube in the gearbox. High 11's on decent tyres shouldn't be a problem. Want occasional 10's?? Install a N20 kit and get it tuned properly, no more than 150hp or your combustion pressures start getting to high for your stock pistons.
why would you pull the motor out and put the stock pistsons back in?
and the crank doesnt need cryo... people have run 9s, and i think better than that on a factory outta the box crank, good enough for everyone else i reckon
Sorry, but if the plan is to eventually rebuild either way, to run 10's you should just bolt a nitrous kit onto the completely stock motor and run it at 14psi on the stock turbos with a good tune on a pfc and some drag radials. $1500 for the ECU, $600 for the tune, $1200 for the drag radials, $1000 for the nitrous kit including a bigger fuel pump, $1000 for the clutch, $15 for a boost controller, (hey this IS sau after all and you're all cheap kents!)
Adds up to under $6k
If it dies, rebuild it then. Not before.
Don't listen to him he is a dirty cheating ricer!
I'd like to see some bigger nitrous kits on RB's myself. I am helping a mate out with nitrous setup at the moment on his LS2 powered torrana hatch and we have a nice little 350 shot sorted out for it.
Might get some action for the bunky GTR happening later as between a few mates there are a few kit bits lying around I could have a go at frankenstiening something from. :D
Hi!
R33 crank
New piston rings
New bearings
Water pump
Oil restrictors
600cc injectors
NISMO AFMS
GTR PFC
or
Clutch:
ORC/HKS twinplate
Rear:
2 way lsd/locker
Thanks!
If your car is running with a striped out that means you dont need much power, simple bolt on mods on a standard engine will get you 11s. I would be more focused on the suspension setup and tire choice, a 300 to 350kw engine will do it easy.
List:
-Standard engine with metal head gasket 1.2mm
-FMIC bout 100mm thick
-Good piping kit
-Power FC D Jetro
-600cc Injectors
-Bigger turbo's N1 equivlent
-HKS Dump pipes
-70mm front pipe
-4 or 5" high flow cat
-3.5"catback
-Quality boost controller running bout 1.2 - 1.3bar
-HKS Drag Coilovers and run 0 camber
-Twin plate clutch
-Nismo fuel pump
-N1 oil pump
If you have most of them parts then the build shouldnt cost to much.
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
