"21. Jarrod Moore Sileightly"
Aren't you meant to be doing something else that weekend...
like taking photos of us :P
Heh heh.... but seriously, how did you convince the owner of the Slightly to let you drive??
Pipe down champ. There will be photos cox I will have new toys but maybe they won't be used on your car.
  • Replies 166
Posted Images
Shepparton is booked pretty much booked out for this weekend.
I have a few things reserved under my name - but in the next couple of days, even those will be taken off me unless someone puts their hand up and says they want them.
If you are wanting to stay for the weekend - PM OR EMAIL ME ASAP with your phone number and Ill call you and give you some details.
If you dont act quickly, there is a very high chance youll miss out - please get in touch with me as soon as you can.
Cheers :blink:
UPDATE - have secured 5 more rooms :rant:
They dont like holding them for me though as its so busy up there that weekend.
Please guys - I cant stress enough - If you need a room, contact me ASAFP - If i dont get names next to these rooms, the hotels will take them back :D
no licence cant make it, was wanting to do it otherwise
Just get someone to drive it up for you and you can thrash it around on the track. That's what I did when I lost mine.
If anyone else is looking for a fire extinguisher this ebay seller is selling some with metal bracket for $10 each:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=150304645268
In Thomastown with pickup only.
To make this DECA a little bit more fun, we are allowing participants to have your say on the morning skidpan motorkhana's... We're calling it "The People's DECA" Catchy aint it?
Click Here - To place a vote.
gareth, i'm 99% down for this so will need a fire extinguisher. What do you think of these? i haven't done any research but i thought they'd be a lot more pricey than $10
anyone else who's got/knows about fire extinguishers think much of the ebay link?
They are from Supercheap Auto, I use the same ones in my cars. Normally priced around $25-30.
so $10 is a bargain then!
i've just net bank'd the $75, and just going to fill out the pdf, take some pics and email it to the motorsport address. Hope that's ok, don't have access to a fax at the moment
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
