http://www.thenewspaper.com/news/25/2572.asp
Great!
Australia Deploys Noise Cameras
Noise cameras become the latest ticketing technology deployed against motorists in New South Wales, Australia.
Noise CameraState governments across Australia are poised to deploy automated cameras that mail tickets to vehicles considered by a machine to be noisy. The fully automated noise camera systems have been in development since 2005 but are now are active and issuing warning notices in the small New South Wales suburb of Mount Ousley, according to the Roads and Traffic Authority (RTA) Annual Report. The agency is looking for a regulatory means of making such ticketing solutions more common.
"The RTA is contributing to the development of the 'Planning Guideline for Residential and other Sensitive Building Developments alongside Major Roads,'" the RTA report explains. "This will include requirements to address noise for new residential development along nominated roads and rail corridors.... RTA continues to develop technology in the form of a suitable noise camera to use as an enforcement device."
The fully automated noise analysis system designed by the NSW firm Acoustic Research Laboratories uses a set of microphones and cameras that continuously record and analyze activity on a neighborhood street. A computer program processes the audio data to isolate trigger sounds from general background road noise. This allows the device find opportunities to mail a traffic citation to passing vehicles that exceed a predetermined noise threshold. Once configured, the machine will generate up to 10,000 tickets before the on-board hard drive is filled. A 10-second video and audio clip is stored for each incident for use in court proceedings.
South Australia and Victoria have begun similar programs with each state focusing on the noise of heavy commercial truck compression brakes, an issue designed to court local approval of the ticketing technology.
"In parallel with the development of the acoustic measurement methodology, Transport South Australia has developed camera technology that can be linked with the measurement software," Australia's National Transport Commission reported. "The combination of these systems offers the potential for excessive engine brake noise incidents to be identified and recorded, which may provide a useful tool to enforcement agencies."
The commission approved the regulation against engine compression brakes last November. The ticketing system can also be easily expanded to issue citations for loud subwoofers, noisy exhausts, or even an inopportune honk of the horn.
https://www.sau.com.au/forums/topic/241393-australia-deploys-noise-cameras/
  • Replies 58
Posted Images
Yes, a baseball bat would do the trick. But how about one of these.....
They did say noise sensitive right?....and space for 10,000 offenders? :D who said it had to be car noises that filled it up - i think music would be alot better use of the HDD :( hehehe
My tyres are pretty loud eh? Stock exhaust/air filter/turbo/car ftw! :D
I see these being mucked with a fair bit... I would totally just set up a speaker near by and have random loud noises happening and random times... like when that cyclist is riding past :(
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
