http://www.thenewspaper.com/news/25/2572.asp
Great!
Australia Deploys Noise Cameras
Noise cameras become the latest ticketing technology deployed against motorists in New South Wales, Australia.
Noise CameraState governments across Australia are poised to deploy automated cameras that mail tickets to vehicles considered by a machine to be noisy. The fully automated noise camera systems have been in development since 2005 but are now are active and issuing warning notices in the small New South Wales suburb of Mount Ousley, according to the Roads and Traffic Authority (RTA) Annual Report. The agency is looking for a regulatory means of making such ticketing solutions more common.
"The RTA is contributing to the development of the 'Planning Guideline for Residential and other Sensitive Building Developments alongside Major Roads,'" the RTA report explains. "This will include requirements to address noise for new residential development along nominated roads and rail corridors.... RTA continues to develop technology in the form of a suitable noise camera to use as an enforcement device."
The fully automated noise analysis system designed by the NSW firm Acoustic Research Laboratories uses a set of microphones and cameras that continuously record and analyze activity on a neighborhood street. A computer program processes the audio data to isolate trigger sounds from general background road noise. This allows the device find opportunities to mail a traffic citation to passing vehicles that exceed a predetermined noise threshold. Once configured, the machine will generate up to 10,000 tickets before the on-board hard drive is filled. A 10-second video and audio clip is stored for each incident for use in court proceedings.
South Australia and Victoria have begun similar programs with each state focusing on the noise of heavy commercial truck compression brakes, an issue designed to court local approval of the ticketing technology.
"In parallel with the development of the acoustic measurement methodology, Transport South Australia has developed camera technology that can be linked with the measurement software," Australia's National Transport Commission reported. "The combination of these systems offers the potential for excessive engine brake noise incidents to be identified and recorded, which may provide a useful tool to enforcement agencies."
The commission approved the regulation against engine compression brakes last November. The ticketing system can also be easily expanded to issue citations for loud subwoofers, noisy exhausts, or even an inopportune honk of the horn.
https://www.sau.com.au/forums/topic/241393-australia-deploys-noise-cameras/
  • Replies 58
Posted Images
Yes, a baseball bat would do the trick. But how about one of these.....
They did say noise sensitive right?....and space for 10,000 offenders? :D who said it had to be car noises that filled it up - i think music would be alot better use of the HDD :( hehehe
My tyres are pretty loud eh? Stock exhaust/air filter/turbo/car ftw! :D
I see these being mucked with a fair bit... I would totally just set up a speaker near by and have random loud noises happening and random times... like when that cyclist is riding past :(
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
