I Striped out my R32 GTR halfcut and these are all the leftover parts that aren't required.
All items available to be picked up from Brisbane Southside but will post small items at buyers expense
Contact details: PM or reply here
Cheers Greg
R32 GTR gearbox, includes front drive shaft $600 Pic
R32 GTR front diff, 4.11 ratio inlcudes everything pictured $250 Pic
R32 GTR cam gears $30 Pic
Tensioner and idler bearing used $60 Pic
R32 GTR floor rubber that goes around shifter $5 Pic
R32 GTR stock castor arms $20 Pic
R32 GTR stock power steering cooler $20 Pic
R32 GTR front shocks (KYB gear climb) and springs, light surface rust $40 Pic
R32 GTR radiator and fan shroud $100 Pic
R32 GTR clutch fan $50 Pic
R32 GTR BOV return pipe that runs behind the intercooler, no cracks $50 Pic
R32 GTR engine mounts $50 Pic
R32 GTR strut brace $60 Pic
R32 GTR stock air box $20 Pic
R32 GTR stock turbos, stock dumps and acuators included $200 Pic
R32 GTR intercooler $100 Pic, Pic, Pic
R32 GTR Clutch and flywheel, unsure on brand it has DK stamped on it, 7.5mm of meat left on the clutch $200 Pic, Pic, Pic
R32 GTR front uprights, includes uprights, hubs, half shafts and lower control arms $200 Pic
R32 GTR front camber arms, unsure on brand $100 Pic
R32 GTR slave cylinder $40 Pic
R32 GTR clutch boost and master cylinder $100 Pic
R32 GTR speedo cable $50 Pic
R32 GTR gearbox mount $10 Pic
R32 GTR steering column includes boss kit $50 Pic
R32 GTR washer bottle $50 Pic
R32 GTR wiper arm $10 Pic
R32 GTR complete Air conditioner setup back to fire wall $300 Pic
R32 GTR indicator stalk $5 Pic
R32 GTR stock gauges $30 Pic
R32 GTR stock boost solonoid $5 Pic
R32 GTR plastic underlining $5 Pic
R32 GTR inner plastic guards, with brake ducts/vents $30 Pic
R32 GTR air conditioner/heater setup behind dash $100 Pic
R32 GTR acclerator, brake and clutch pedal $60 Pic, Pic
R32 GTR radiator overflow bottle, has small chip off it $10 Pic, Pic
R32 GTR dash $100 Pic
R32 GTR front sub frame $80
R32 GTR power steering resviour $20 Pic
R32 GTR random interior parts, PM me what you want with a price Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/
Hey mate im after the window controls on both sides.
Front left head light by any chance?
Hey, would you happen to have the bonnet latch and vertical support?
Thanks!
The halfcut didn't come with any of those parts
BOV pipe, im 99% on that - would you be happy to post it?
Yeah i will post that out to you
What sort of condition are the turbo's in?
I just pulled the dump pipes off both of them, 1 has minimal shaft play the other is missing the exhaust wheel :P
New Price on Turbos $50 includes stock dumps and acuators
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4240608
R32 GTR stock air box SOLD
R32 GTR stock turbos, stock dumps and actuators included SOLD
R32 GTR intercooler SOLD
R32 GTR front camber arms, unsure on brand SOLD
R32 GTR stock gauges SOLD
R32 GTR inner plastic guards, with brake ducts/vents SOLD
R32 GTR dash SOLD
R32 GTR radiator and fan shroud SOLD pending payment
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4248159
R32 GTR dash SOLD
Pm sent
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4248370
got a grille??
G'day mate
Would you have a pair of front indicators for sale?
Cheers
No, the halfcut didn't come with any exterior panels
hey mate, dont suppose you have the fuel pump cradle + rubber mounts for sale??
No i didn't get that with the halfcut
R32 GTR steering column includes boss kit SOLD
R32 GTR washer bottle SOLD
R32 GTR front diff, 4.11 ratio SOLD pending payment
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4254494
hey man
just wondering if you got:
Handbrake assembly with good stiching and handbrake boot in good nick, and also a good nick gear boot?
PM me if u got these parts man
cheers
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4255634
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
