I am going to summernats this year and was thinking about entering the burnout comp, I also would like to enter power cruise next year as well.
My question is, about the RB oil issues, I know there are problems with high revs and oil control but my question is, how about reving high for 2 minutes flat?
4th gear and 240km'h wheel spin at 6000 to 7000 rpm, I was thinking that it may be impossible without a dry sump setup and some serious oil returns.
Anyone have any ideas ? or should i just scrap the whole idea alltogether. I am not going to go with a dry sump setup, i just do not want to spend that kinda money when i will only really need it for burnouts.
I am a big burnout fan from years ago, I have won a few comps but back then the other cars are nothing compared to what I will be up against at these events.
So yeah I know its been covered before for track cars and street cars, but what about 6000rpm for 2 minutes flat. I will be spraying water over the radiator & oil cooler to keep the temps at acceptable levels.
I am running a N1 pump, so it would probly empty the sump completly after about 30 seconds or less
any ideas anyone?
https://www.sau.com.au/forums/topic/244625-high-powered-rbs-and-burnouts/
  • Replies 67
Water spray on anything that makes heat, diff, gearbox radiator, oil cooler, intercooler, just do some ghetto setup with irrigation sprayers, $100 spent here could easily save $$$$'s Hope you have an oil temp gauge.
Edited by Adriano
Once the tires are spinning you are not full throttle, right? it isn't the revs, it is the amount of continuous power output that generates heat.
7000 rpm at average 1/3 throttle is not the same as 7000 rpm wide open throttle.
and aren't the rb oil issues mostly related to g-forces? the trust sump is big to avoid oil starvation during high g, baffles in the sump
address the same issue.
Finally... something along the lines i am looking for... Yes your right there will be no g forces except for circle whips which won't be much.....
Maybe i just need extra cooling for the job ? i am thinking once the wheels are spinnning i won't need to be on full throttle and i should be able to drop the revs down to 5,500rpm or so....
interesting.. might chuck on some tyres and do some test runs to see how this car goes doing burnouts
did you put the oil restrictors in when you built your RB30?
PS. come out and say hi to the ACT people while you are down here :P
yeah i did, i am thinking i just need a bigger sump, and a little more oil with some cooling.
I will be down for there about 5 days so sure why not :D its going to be a big one this year because we will be there for NYE, whats to do in ACT on NYE ?
Lunch it in the quest for a burnout title and ill rebuild it for expenses only...Running Red R Racing decals on the car is a mandatory requirement. I have a big oil cooler you can borrow.
Give it to me and I garuantee you paul will get to honour his above mentioned commitement. :D:P:)
Edited by FineLine
The oil restrictors should help a bit with the oil control, perhaps over fill it a bit and test out how the oil pressures go.
RE, NYE. not a massive number of options, if you want to stick with the "summernats" theme you could get drunk in civic and then watch the fireworks. (assuming you are staying north side) or you could visit fyshwick or mitchell for some "adult entertainment".
A lot of places actually close down during summernats as its quite a hassle dealing with all the drunks.
HELL YEAH!!!
I will hold you to this one mate.. i know where you are :P
wouldn't have said it if i wasn't serious....its not Friday
sweet. So i take it your going to come down and bring my spare gearbox and diff in the jeep? besides.. i need you to help me replace any bits that go kaboom :P
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
