The watch made the connection from the positive terminal of the uncovered fuse box to the throttle body. But it gets better - To get the spanner I was using onto the oil-filter fitting I was doing back up, I'd had to wiggle my arm down in the gap and jam it there. When the watch made the connection, it wasn't just a simple case of pulling my hand away. It was stuck for what seemed like ages.
Lesson well learned. No jewelery when working on the car and ALWAYS use the battery master shut-off.
More than a month later, it's still not great.
  • 3 months later...
Kel! what are you doing to yourself! don't use your knee as a brake...
You should see how the car bit ended up :P
As I've said before, I should stick to somewhere safe, like the nav seat.
My worst injury from my down-the-bank adventure at Wrestpoint Targa was the bramble scratches I got climbing 12 foot back up the bank to the road!
I think you should harden up girl.
Oh a little bruised knee hardly rates on the raceworx scale of injuries.
Neil.
picsorban Neily is the only way to claim top raceworx injury status
Hmm, Can't top the watch one, but if there's a wooden spoon for biggest pratt: here's my pitch.
I normally only wear ear protection when I'm doing something loud.
I was using my plasma cutter, and it wasn't that loud so I just wore an oxy mask. Of course, plasma cutters blow away the molten steel. Out of the corner of my eye, I see a bright red ball of steel go up from the cutter, bounce off something, and feel it go into my left ear. @#$@#$ me it hurt. Makes note to self: wear ear protection when plasma cutting.
Two days later, using the Mig welder. Wearing the full auto lcd facemask, but no ear protection, as I thought the facemask was enough protection. I'm welding, hear this pop, see a bright red ball of steel go up, bounce off something, and feel it go into my left ear. @#$@%# me, that hurt too. Turns out my big fat head and my wing nut-air brake ears are quite effective at collecting flying debris.
Went to the doctor. He said I had 2 balls of steel in my ear canal, about 1mm from my ear drum. Tried to wash it out with a syringe but failed, so had to go to a ear-nose-throat specialist. Turn up to the specialist, and he's got a dentist's chair, and a german bedside manner kinda like the dentist in the marathon man movie..
Puts me in this dentist chair, and uses tools I can't begin to describe to dig these bits of metal out of my head. It hurt more than anything I have ever felt in my life, including the time I used a pipe wrench to shatter my thumb into 5 pieces (a whole other sorry story :D)..
300$ and a whole lotta pain later, I now wear ear protection, even when making toast...
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
