Driver Dynamics Beginners Drift Day Sandown Saturday 17th January 2009
If you’ve always wanted to have a go at drifting on the circuit, but didn’t want to attend a fully blown drift day, then we have a course that will suit you perfectly.
To be conducted at Sandown on 17th January 2009, this day is aimed at drivers who want to have a lot of fun and learn plenty about drifting from Australia's best professional drifters including Adam Newton and Luke Fink.
The exercises will be conducted on wet roads to keep the speeds down and minimize wear and tear on your car.
The cost for this course is $195.00 including lunch and refreshments.
We’re taking bookings now, so if you’d like to attend give us a call on 1300 652 693
  • Replies 147
Posted Images
eek...this should be fun. how is the track gonna be set up? diff groups diff sections? learning how to link corners? semi-high speed corners? how close are the barriers again?...lol
+1 More info on the day please, Wet track ie. Large Skid Pan with cones?
who in their right mind would drive an auto sk.....oh....
I've organized early skidpan days in 2003, and there's some auto cars attended, including a benz, which are purrfectly fine for drifting.
It's the driver who drifts, not the car. If you got skills you can even drift a rickshaw if you really try hard...
yeah but basti has only had exp driving these things, and well i dunno man......skyline is a whole new ball game :)
will a tiptronic with foot brake (not hand brake) will cut it?
well if u block, by putting a chunk of wood or something there, the release lever so it'll always release the hand brake when ur foot's off it shud work.
so i'm guesing this is gonna happen in the car park? how much track time each?
is this the same as a cams event so needed is a day's cam's license and gear would be required such as adr helmet long sleeve's and closed footwear ?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
