thanks guys. i'll just put the factory hicas system back in. now with the exhaust, its got a 3" turbo back. do they just check the db? whether they do or dont, if i put my stock cat back exhaust on would that pass? ie 3" turbo to cat.
Edited by Nozila
Just reading back from the thread,
My car is currently awaiting its 2nd inspection and im looking for 2 parts.
1. tie rod ends
2. castor rod bushes
I've called regency 2 times so far and both said rose jointed stuff is illegal. I made a mention of grease nipple type which one of the operators said that they will double check and then came back saying no not allowed either way.
So my question is, what can i get to replace the tie rod ends and castor rod bushes that is definately legal? i.e. what brand/type of stuff have people been through with and were passed with as regency information centre is as reliable as a cheap chinese dildo.
Also worth mentioning is that I've already talked to few import places and no one can get new factory tie rod ends so it seems.
I just replaced my tie rod ends a couple days ago - $45 each at Jap Import Spares($65 each at Autotech, $110 each at Niswreck). Castor Rods be done in the next few days sometime, my bushes are Mcf**ked too - might be borrowing off a mate but cheapest I got quoted was $85 each at Jap Import Spares($125 each at Niswreck) but I'm considering getting the bushes re-done($150 for both bushes) but awaiting a mate to get back to me see if he can source a set of Castor Rods for cheaper.
Yep - db test at idle and up to 4000rpm (or 4500rpm).
Had to be lower than 92db! So shove the stock cat/baffles/steel wool/a small rabbit in there to quiet it!
as you can see, im a defect virgin. never been defected before. my mate told me about the brake test, to see how long it takes to stop - im assuming that what you are referring to preiss.
with the wheels/tyres, i had a mate who went through with some jap rims [17"] a few yrs ago, and they were fine. as it seems to be somewhat difficult to source stock r33 rims/tyres atm, would his rims do? the reason why i ask is because the mate who told me about the brake test [who went through defect himself a while back] said they look at size and profile of wheels/tyres.
Yep - size of the rim cannot exceed 2" from what's on your tyre placard... so, say, Skylines came out stock with 16" rims... you can have any type of 17" mag on there and get though BUT the width of the tyre must not exceed more than 10mm from that's on the tyre placard (pretty sure it's 10mm or 25mm...)
Brake test is when they put your car on rollers, get to a certain speed (pretty sure it's 60k's) and either rip up the handbrake (that's what they did in my car!) or slam on the pedal brake. The car must stop within a certain amount of time. Slotted rotors are fine... but if you have massive rotors, you might not be able to put a smaller rim on to pass Regency!
Ive been thru regency 4 times with various wheels. Never checked them.
As long as they arent hugely oversized should be fine.
yeah the brake test is pretty simple. never heard anyone failing that .
my rotors aint slotted, the brake disc is just really thin. thats what the guys said to me a few years back when he put my brake pads on to bleed them and wear them in.
what about exhaust? aftermarket exhaust that is under a certain db would pass? i really cant be bothered putting the stock exhaust back on.
also, do you need rear brake lights - the middle one, not just the four rounds ones? as i got a stealth wing. if you do, can i just hook up a rear brake light inside the car?
Edited by Nozila
Yep as long as the aftermarket exhaust is under 92db @ 4-4500rpm then you'll be fine. Just shove a heap of shit into it to quiet it down! Steel wool works a treat... take it easy on the way there and just rev the shit out of the car after you leave and watch it fly out :) but baffles, another resinator, etc will help.
There's no restrictions on how large the exhaust is... as long as it exits out the back of the vehicle, doesn't protrude out the rear bar too much, and if it's angled, it MUST be angled to the right (stupid, but true!).
Edited by CRoNic...
You will be very suprised with your exhaust.
I had a loud exhaust I thought. and a nice size too.
It passed . - 88db
of the 4 times ive been there, ive only been tested once for db.
take it easy when u go in and you may not even get tested.
cronic
you pulling my leg mate? angled to the right, how is that possible? i think all af exhaust are either straight out the back or angled to the left. damn, i guess my stock exhaust must go back on then.
Lol let me get the rules... hang on...
Edit: Here!:
EXHAUST SYSTEMS AND NOISE
Replacement Exhaust Systems
Extractors and aftermarket exhaust systems may be fitted provided that the sound levels specified in the Road
Traffic (Vehicle Standards) Rules 1999 are not exceeded. On vehicles required to comply with ADRs 26, 27 or
27A, extractors may be fitted provided that any emission control devices, which were originally fitted to the
exhaust system, are re-connected and operative. Vehicles required to comply with ADR 37 or 37/.. may be
fitted with extractors or after market exhaust systems provided that the catalytic converter is retained and any
emission control equipment fitted to the original exhaust is incorporated in the replacement item.
Exhaust Outlets
For vehicles manufactured prior to July 1988 the requirements are not specific, however, vehicles submitted to
Transport SA will be acceptable if:-
a. The exhaust outlet exits beyond the last door or window opening on the side or rear of the vehicle;
b. The exhaust outlet is as close as possible to the outer edge of the vehicle but not outside or underneath
the vehicle;
c. The exhaust system, if contactable, is adequately shielded and any sharp or hazardous projections are
suitably treated.
For vehicles manufactured on or after 1st July 1988
The exhaust must exit to the rear or on the right hand side and extend at least 40 millimetres beyond the
furthermost outboard or rearmost joint of the floor pan that is not continuously welded or permanently sealed.
No exhaust outlet is to extend beyond the perimeter of the vehicle when viewed in plan.
The exhaust outlet, if to the side of the vehicle, shall discharge to the right hand side of the vehicle and
downwards at an angle to the horizontal of not less than 15 degrees and not more than 45 degrees.
The exhaust outlet, if to the rear, shall discharge at not less than 10 degrees above or 45 degrees below the
horizontal.
Exhaust Noise
The exhaust systems on vehicles manufactured on or after 1st January, 1974 must at the time of first registration
comply with ADR 28 - Motor Vehicle Noise.
In service all vehicles must comply with the Road Traffic (Vehicle Standards) Rules 1999 Part 10 Division 3 –
Noise Emissions.
For passenger cars, derivates and panel vans manufactured on or after 1 January 1983 the stationary noise level
when tested must not exceed 90 dB(A).
Transport SA
September 2003 Modifications to Passenger Cars, Car Type Utilities and Panel Vans Page 13 of 25
Passenger cars, derivates and panel vans manufactured before 1 January 1983 the stationary noise level when
tested must not exceed 96 dB(A).
Edit: I fail. It says that only applies to exhausts coming out the SIDE of the car! Sorry dude lol. I was reading it quickly the other night!
Edited by CRoNic...
WTF i called jap import spares and nisswreck and they both told me that they cant get new tie rod ends :S:S fk my luck
anyways, I found a dude in SA that sells new ones for $29 each and a set of non adjustable castor rod bushes for $59 (but then you need to get them pressed in)
he's on ns.com as a trader "Shock Systems" if you're interested.
www.shocksystems.biz
hmm looking at my exhaust from the side, it still sticks out of the rear bumper a bit. im not gonna take a chance on that. do they check all the hangers of the exhaust system, cause since its aftermarket atm putting the stock one on would leave a few hangers/rubbers joints unused.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
