The headlights are fine but they have to be fitted with Halogen globes, HIDs are only legal if the car is fitted with auto leveling headlights. BMW = Auto leveling, Skyline = no auto leveling.
I wish that shit was written in a place where it was easily accessible
The difference between makes is pretty stupid - one rule should apply for all cars - and the govt should be erring on the side of leniency...
not because i think it'd be easier, but our car manufacturers spend a load of money doing R&D, and that excuse is used on a contrary point of view for minor mods (like air intake, exhausts, tunes etc) - so why cant that same standardisation rule be applied for aftermarket addons that actually help? (legal and professionally installed of course)
Seems our govt thinks that the car manufacturers know it all, and ergo all aftermarket mods are done by 'hoons' even if its something as innocuous as a pair of spotlights...
this is the shit that pisses me off.... nanny state, hand holding, ignorant politician preaching crap, designed to either a) harvest more taxes or b) crack down upon personal freedoms to make the politicians job that much easier - its easier to answer the crowd when half of the crowd are muted...
*yawn*
as if politicians have a hard job... they dont even appear at parliament regularly
-D
REPORT HIM!! I got let off before for a $580 fine because he abused me and smoked in my face, it works!! do it and don't be hesitant.. I just came out of regency too, so long as ur exhaust is lower than 90dB at 3,300 rpm then you're fine, and it depends on who you get in regency :D
goodluck!!
REPORT HIM!! I got let off before for a $580 fine because he abused me and smoked in my face, it works!! do it and don't be hesitant.. I just came out of regency too, so long as ur exhaust is lower than 90dB at 3,300 rpm then you're fine, and it depends on who you get in regency :blink:
goodluck!!
Report who?
Edited by Rolls
hi, anyone had any defect issues with clean looking stageas? legal or not what sort of unwanted attention has anyone had?
ive only been pulled over once, random breatho. no defect. no checks. was after i had already parked and car was off.
i shit myself any time i see a cop :)
im unsure if recirc catch cans are legal, and is boost gauge under dash legal?
cheers.
cheers.
Yes provided the entire stock crank case ventilation system is in place and you have simply placed the catch can inline with this system. I went through regency recently with this and had no issues.
i shit myself any time i see a cop >_<
cheers.
I live near the Ottoway police station. My Stagea has a bodykit, mags etc ... so its not subtle. I see cops all the time and they leave me alone. :thumbsup:
its the mars bars phone number :D
i was being smart ass
Vehicle Standards/Modifications/Engineering 1300 882 248
i knew that was sus :cool:
bit weird you would have that number :)
thanks for the correct help tho, though ill believe its the right number when i find out lol
Edited by ON EDGE
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
